below you see my description of my stereo
im making a bad mistake by not even having a cap on the system (ran out of money)
how bad is this hurting my alternator and amp and sub
at idle i have 13.8volts at the amp but when its cranked up i go down to about 12.5volts
i dont crank it up a lot just because im scared but how much damage could it be doing to my electrical system or my electronics
dont worry i will be getting a cap soon possibly a battery if i can get one cheap
dont waste you money on a cap, instead do the big three and get a good battery to put in the back.
but im not running anything big i probably running just over 1000rms(at the most) for the entire system i dont see the need for the big 3 i might get one of these at the most http://www.sonicelectronix.com/item_7324_Kinetik+HC+600.html i dont think i need that much because i dont plan on upgrading my system(subs and amps) anytime soon for sure
what is the problems with caps thats what i want to know cause i see me being ok if i got a 2 fared cap for my system somethin like this http://www.sonicelectronix.com/item_6937_P...E+COMPACT-.html
The main problem with caps is that they hardly hold any power at all, I think my 1.5 farad I got off a friend for dirt cheap would only hold my amp on without any signal input for a couple seconds max. Remember that is without any speaker use at all, just the amp. Therefore, the cap isn't going to be able to sustain your voltage with the amp putting out power for any measurable period of time. On the other side, the big 3 will help get power from your alt and front battery to your amp, keeping the amp's voltage up. If you want, use a dimm and measure what your voltage is at the alt when your bass hits. I guarantee it is a good amount higher than what your amp is seeing at the same time.
your car will spend more electrical energy trying to charge a cap than it will trying to charge a battery. A cap is designed to release all of its energy at once, where a battery is a constant steady supply of power.
I think that is right. some body back me up or correct me on this...
2007 Toyota FJ Cruiser Voo Doo Blue
my upgrades and "build" thread.
My Kulicki Box Build
-Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars
-Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash )
-JL Audio 2 way Component set XR650CSi
- Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box.
-Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio
-All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0,
-270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum-
-2 Powermaster D680 Powercells in back
FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz.
Shoehorn, BFH, forklift,duct tape and some zip ties
  • Who's Online   0 Members, 0 Anonymous, 1378 Guests (See full list)
