Electrical porblems??
finally got my setup going after all the hard work, 18'' ssa icon in 6cuft box tuned to 33hz, ran with a brz.2100.D
well heres my problem, i can turn it up and it be loud but after about 10 minutes or so, the amp shuts off, and is pretty hot. thought i may have blown a fuse, but fuse is fine, i guess its just the amp overheating. another thing is when everythings running fine and its hitting good my capcitor stops reading numbers and just reads 3 small lines across the screen. im running all stock electrical, and running 4 guage power and ground, and small fuse block with 80A fuse. Also for this amp to be so big and the sub only able to handle 1250rms my amp is turned 3/4 of the way up?
if anyone can help me it would be very much appreciated, just point me in the right direction. im very sure that i dont have enough power, do i need an extra battery, alternator, bigger wires, or what? i just dont want to go spending money not knowing what i need,
33wodj9.jpg[/img]
24cb4ok.jpg[/img]
Step up to 1/0 and ditch the 4awg cause it will really strain your system running wire that small on that amp.
Thar smaller power and ground wire isn't letting enough power get to the amp so it is heating up from the low voltage.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
If your cap is reading 3 small lines... I bet your Under 12v, which will heat the amp up quick, putting it into thermal protect.
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
thanks, i thought that was a problem, cause when i go to the back and grap the power the wire is prettyyyyyy damn hot.
You would be better off with a second battery than a cap. But you are probably dropping under 12v bad if you have stock electrical. Have you done the Big 3 and have you thought about an ALT
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
yeah, i noticed when volume is down im sitting at 14v but as i crank the volume up it drops to 13v, then to 12v, and then blank lol. most noticeable with low notes. what would be your suggestion to solve this??
No, its all stock, under the sub box is my battery and spare tire, so i just got power and ground ran there, straight to cap, then to amp. so the wires are maybe 2 1/2 foot.
if i got a second battery to put back there, i would like to go with xs power batts, any suggestions on which one? and i have thought about getting a mechman alt but im trying to stay away from it unless i absolutley need it, because of price.
Turn your gain down a bit, you need bump up your eletrical, unless your stock alt is 100+ you need to get a new one soon. And take the other advice stated in this thread, get rid of the cap!
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
okk, thankss
more electrical support, 1/0 OFC wiring, and common sense are needed (if your cap stopped reading voltage, that should be a red flag)
  • Who's Online   0 Members, 0 Anonymous, 814 Guests (See full list)
