How to properly tune a line driver with DD1
This is a piece that is overlooked by so many when tuning a system. If something isn't set right, the blame always goes to the sub and amp when in reality the line driver is probably the cause. That was the reason I made these videos.
I had a shop installer tell a customer that his 1.2k and level 2 were bad because, 1- he didn't know how to properly tune the system or 2- he is a shady mother fucker and just wanted to sell the jl product he carried instead of correctly setting up the equipment supplied by the customer.
The piece in question was an audio control lc2i. The installer told me that the amp would distort at ANY gain level. WTF! Had no clue what I was talking about when I asked him what the input voltage was from the line driver to the amp. (MAJOR RED FLAG)
My customer believed him since he is the shop installer and is supposed to know what he is talking about. He sent his 1.2k and sub back in to be tested just to find out that nothing is wrong with either.
These basics were one of the first things that I learned when I got serious about car audio, thanks to this site. I find it fucking pathetic that an experienced installer can't get something like this right and cost his customer money by having him send the equipment back to be tested.
An installer should know the basics and be able to at least get the settings close. But as an installer you are only as good as the tools you use. Steve and Tony are providing the industry with the proper tools to make installing/tuning aftermarket car audio very simple and easy to understand. Every shop should have these tools in their tool box!
  • Like (+1 Rep) 2
dude, Bro, MY MAN.......those were GREAT video's. Thanks so much for taking the time to make them and post them up. :drink40: Everything you said makes sense. In the end, if you have a line driver, chances are, your amps gains will be all the way down or barely up. That is because the gain is then properly matched to whatever is in front of it. In this case, the amp being fed PLENTY of input voltage. No need for extra gain and the dd-1 proved that. And like i been stressing, that is the gains one and only purpose. To be matched to its source's output. I don't know why people, especially people that should know better, are so hard headed and try to argue with me :D.
But for the Ear-o-tuners, i will say this. Once you find your maximum non distorted output, and all gains are matched, it never hurts to turn them DOWN a little.......while tuning by ear, if you need to. Heck, thats why there is overlap tracks included 8) . There's obviously more to tuning then just the DD-1. The ears will come into play for SURE. But, i will argue til i am blue in the face......a DD-1 OR an O-scope should always be your first step. Ear-o-tune away once you know you are safe!
Follow my Tweet (Twitter)
good job Cody. We found last year that my maxxlink was distorted all the way through even when it was turned down as low as it could go :(
:ninja:
i did Rusty's Max-Link and although i didn't understand the double-gain thing (why they did that), his wasn't too dirty. I was able to set the gains and get clean signal out of it. :)
Phenominal... I just printed out the steps you wrote so I can properly set everything when I swap headunits. Thanks for great videos.
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
NICE video!
Lots of advice out there to use line drivers with HU's that have "low" output voltages.
This is a great example of how LD's can actually cause more harm then good.
:good:
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
There is a place to use a line driver. Most cases are with stock headunits that have weak preout voltages. If you have a good aftermarket headunit with a 2v+ preout voltage, then there is no need for a line driver. I just had to use my bench to show the test.
Is there any advantage using a line driver with a aftermarket Head unit 2v preout voltage?
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
Great video
Battery = XS D3400
Sub= Kicker L7 12"
  • Who's Online   1 Member, 0 Anonymous, 1168 Guests (See full list)
