S15_Silvia Posted October 16, 2012 Report Posted October 16, 2012 Hey guys, so I have a home setup consisting of an Audioengine D1 digital to analog converter being fed optical from my laptop, going into a Logic3 Valve 80 hybrid tube/mosfet amp. I took the whole setup down to the labs in my engineering building and individually scoped the DAC and the amp with a 40Hz and then 1KHz WAV file, both -3dB. The scope showed zero clipping, even with both the amp volume and DAC volume maxed. Is this really happening? Because that's pretty neat if yes. 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
Swordlordboy1234 Posted October 16, 2012 Report Posted October 16, 2012 An amp and HU have zero clip at max volume for both 40hs-1khz -3db? I'd like to see a DD1 put on this case. Doubtful IMO, but impossible? I'm sure nothing is impossible to some degree My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
S15_Silvia Posted October 16, 2012 Author Report Posted October 16, 2012 Well, it's a home setup. But yeah, the wave was smooth, even after adjusting the vertical/horizontal scales to get a closer look. 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
Skullz Posted October 16, 2012 Report Posted October 16, 2012 If the scope shows no clipping than your good to go. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
S15_Silvia Posted October 16, 2012 Author Report Posted October 16, 2012 I about shit myself when (after already establishing that the DAC can be maxed) I turned the amp up and it just kept staying smooth. 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
Swordlordboy1234 Posted October 16, 2012 Report Posted October 16, 2012 If the scope or dd1 says so... Then what's the problem? My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
S15_Silvia Posted October 16, 2012 Author Report Posted October 16, 2012 Just disbelief I guess. Pretty crazy. I'm not sure I'd want to know what that signal would look like if amplified out of my laptop's headphone port though. 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
HunterJohnson Posted October 16, 2012 Report Posted October 16, 2012 Just disbelief I guess. Pretty crazy. I'm not sure I'd want to know what that signal would look like if amplified out of my laptop's headphone port though. if you hav an eq boost on your laptop then it might clip Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
S15_Silvia Posted October 16, 2012 Author Report Posted October 16, 2012 Yeah, no EQ involved in this test- that and the volume was only being controlled at the DAC and amp, since you can't really change the output level of an optical source lol 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
HunterJohnson Posted October 16, 2012 Report Posted October 16, 2012 Yeah, no EQ involved in this test- that and the volume was only being controlled at the DAC and amp, since you can't really change the output level of an optical source lol seems clean dude play it max!!! hope your speakers can hang tho Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
