DC Sound Lab
Sub and port location: Level 4 in hatchback
Hello !
I'm about to build a box for Mazda 3 5 doors (hatchback).
The equipment is:
single 15" Level 4 with XL soft parts
Celestra DA2K (2100RMS)
My question is:
What is the best locations for the subwoofer and port?
would it be better putting them on different sides, like sub upward and port firing to the rear door or the opposite maybe ?
u can keep sub facing up(roof) and port firing towards passenger /driver side
or keep both sub n port upwards
your call
@My OpiniOnZ MAy HaVe ChanGeD, But Not The Fact ThAt I'm Right.........!!
What do you want out of this sub? Tuned that low with that much port, I don't think you will be able to hit 31hz
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
I've always been told sub up port back is a good general rule of thumb. If you do go port back you have to make sure you have enough room for the port to breath can make it harder with a bigger box.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
At minimum must be the port's width from the the hatch.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
yep, my last box had the sub and port facing the same side. had it facing the rear with only about 2" of space with the port being about 4" wide did a 144 turned the box and faced it up did a 146. audio control meter
so what ever design you pick make sure you will have enough room for that port to breath and if you chose to have the port and sub on the same side have it meterd facing every possible direction.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
