kingkongthumpin Posted October 17, 2012 Report Posted October 17, 2012 I have 2 pioneer ts-w3002d2, They are dual 2 ohm subwoofers and a lanzar vector 4000 watt 2 ohm stable amp! how could i wire this system up to make it work?
CHEVY4X4BLAZER Posted October 17, 2012 Report Posted October 17, 2012 You need a series/ parallel configuration. Wire each woofer up to 4 ohms. After that, connect your remaining + and - from BOTH woofers together.
Ram1989custom Posted October 17, 2012 Report Posted October 17, 2012 Series Parallel. On each sub, run a jumper wire from one voice coils positive to the other voice coils negative. You now have one positive and one negative remaining on each sub. Run the Positives from each sub together and the negatives from each sub together. That will give you a final 2 ohm load. Edit: Ninja'd. Haha. 1989 Dodge D150, 318 LA; Holley Fuel InjectionBuild Log:http://www.stevemeadedesigns.com/board/topic/72838-dc-dodge-d150-blowthrough-thread-updated-pics-fixed-2-level-4-15s-wlvl-5-coils/Truck Add-ons: 20" rims2/4 drop15% tintBucket seatsK&N air filterSmog Pump deleteStereoWORK IN PROGRESS2 DC Level 4 15s with Level 5 Coils1 Audiopipe AP15001D (Soon to be a Crescendo BC3500)JBL 650W amp (unsure of model)4 6x9 Rockford Prime 3 ways2 Soundstream TWS.4 Dome tweetersKnuKonceptz 1/0 Power Wire *3 Kinetik 2400s and a Mechman 270A alt in the future*
Ram1989custom Posted October 17, 2012 Report Posted October 17, 2012 1989 Dodge D150, 318 LA; Holley Fuel InjectionBuild Log:http://www.stevemeadedesigns.com/board/topic/72838-dc-dodge-d150-blowthrough-thread-updated-pics-fixed-2-level-4-15s-wlvl-5-coils/Truck Add-ons: 20" rims2/4 drop15% tintBucket seatsK&N air filterSmog Pump deleteStereoWORK IN PROGRESS2 DC Level 4 15s with Level 5 Coils1 Audiopipe AP15001D (Soon to be a Crescendo BC3500)JBL 650W amp (unsure of model)4 6x9 Rockford Prime 3 ways2 Soundstream TWS.4 Dome tweetersKnuKonceptz 1/0 Power Wire *3 Kinetik 2400s and a Mechman 270A alt in the future*
C-Fizzy Posted October 17, 2012 Report Posted October 17, 2012 And just so you know, that isn't a true 4,000 watt amp. under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy?
kingkongthumpin Posted October 17, 2012 Author Report Posted October 17, 2012 Series Parallel. On each sub, run a jumper wire from one voice coils positive to the other voice coils negative. You now have one positive and one negative remaining on each sub. Run the Positives from each sub together and the negatives from each sub together. That will give you a final 2 ohm load. Edit: Ninja'd. Haha. Thank you soooooooo much bub you was sooo much help And again thank you!!
Ram1989custom Posted October 17, 2012 Report Posted October 17, 2012 No problem 1989 Dodge D150, 318 LA; Holley Fuel InjectionBuild Log:http://www.stevemeadedesigns.com/board/topic/72838-dc-dodge-d150-blowthrough-thread-updated-pics-fixed-2-level-4-15s-wlvl-5-coils/Truck Add-ons: 20" rims2/4 drop15% tintBucket seatsK&N air filterSmog Pump deleteStereoWORK IN PROGRESS2 DC Level 4 15s with Level 5 Coils1 Audiopipe AP15001D (Soon to be a Crescendo BC3500)JBL 650W amp (unsure of model)4 6x9 Rockford Prime 3 ways2 Soundstream TWS.4 Dome tweetersKnuKonceptz 1/0 Power Wire *3 Kinetik 2400s and a Mechman 270A alt in the future*
kingkongthumpin Posted October 18, 2012 Author Report Posted October 18, 2012 So will i get the maximum power running them this way? so would i just use one channel run the hot to one and the ground to the other?
ChevyBoy95 Posted October 19, 2012 Report Posted October 19, 2012 You wil get full rms like that. Probably around 1000-1200rms.(120a of fusing) Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
kingkongthumpin Posted October 20, 2012 Author Report Posted October 20, 2012 okay if i wire my system like that do i only run it to one channel or split the wires and use both channels like run the hot to the hot and run the ground to the dround or just hook the 2 wires coming out to one channel hot and ground! im using 14 gague speaker wire and i split it down the middle about half way and run it to the hot on 1 speaker and did the same for the other and did the same for the ground and i have 2 wires sticking out of my box do i split the wires again and use both channels or just hook them up to one channel?
