94jettameowpsst Posted October 17, 2012 Report Share Posted October 17, 2012 Will 7/8" maple plywood work for building a box this big? Obviously I may need more than one layer for certain parts but it seems to me it's more sturdy than mdf and its 30/sheet 150.1 @ 38hz142.3 @ 20hz (windows down)Only 2 batteries Link to comment Share on other sites More sharing options...
RAM_Designs Posted October 18, 2012 Report Share Posted October 18, 2012 If you're using beefy subs and running a good amount of power to them, go ahead and double up everywhere. Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011... Link to comment Share on other sites More sharing options...
the_garynator Posted October 18, 2012 Report Share Posted October 18, 2012 I'm running a level 5 15" (m1) on 3kw, I'm running a 3.75-4ft3 box with external aero ports. It's 3/4 mdf all of the way around with a double baffle for the top (2x 3/4"). I have no issues with it. It has liquid nails on everything except for the double baffle/top (the top needs to be removable so that I can get the sub out easily, well as easily as one can remove an 80lb sub lol). I have also done short strand (would do long strand if I did it over again) curves in all for corners (similar to 45's) and all 4 bottom corners, and glass resin'd the inside and outside of the box, although it held together fine before any of this was done). Assuming Maple plywood is at least as strong as mdf, I'd say you won't have an issue. I'd recommend doing some bracing though. either 45s or a threaded rod at the weakest point. (reason I haven't done a threaded rod is there is that there is no room for me to put one that would be of any value structurally speaking as my lvl 5 blocks those places). Current Build: Project Flexington: 157.6db @ 37hz Parallel 6th order walk through, DC Neo Elite 18s, 4 DC 5.0ks, JY Lithium, 12 banks of XS Caps Old Builds:150db and HAIRTRICKs from 2x 12" Power Acoustik Mofos (6th order blow through) ;<p>Roadmaster Wagon Build - DC LVL 6 M3, Kicker Warhorse ; Godzilla swapped 240sx ; 6th Order Bandpass Alpine Type R 12 ; Fully loaded DC Level 5 18" 240sx Link to comment Share on other sites More sharing options...
94jettameowpsst Posted October 19, 2012 Author Report Share Posted October 19, 2012 Thanks for the replies On top of that anyone have suggestions on a port? Well, the one I'm considering in particular is the one Meade uses in his Tahoe, basically just a square hole measured out to whatever it needs to be for say 32-33 hz 150.1 @ 38hz142.3 @ 20hz (windows down)Only 2 batteries Link to comment Share on other sites More sharing options...
94jettameowpsst Posted October 19, 2012 Author Report Share Posted October 19, 2012 Any input in this? 150.1 @ 38hz142.3 @ 20hz (windows down)Only 2 batteries Link to comment Share on other sites More sharing options...
bighossf150 Posted October 19, 2012 Report Share Posted October 19, 2012 Im using 3/4" mdf, double front baffle, 2 layers of chop mat in each seam on the inside with around 2 gallons of resin and a bunch of 3/4" threaded rod for bracing Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s Link to comment Share on other sites More sharing options...
