How do you remove a heated sound deadener that has sticked at a metal surface?
Nissan Frontier
10" Cadence Midbass
8" Cadnece Midrange
Bullet tweets
2 Re audio Sxx 15 Subs
Mechman 270a
2 Re XT4000deV3 mono 1600 rms
1 Re XT400deV3 Bridged 350x2
2 Cadence 175.4 Bridged 350x2
Audiomaxx and Stinger 0,4,8,12 awg wires
Dynamat sound deadeners
My Build Log: http://www.stevemead...__+1999 +nissan
you can try dry ice or an aresol can of freeze spray and a chisel to just pop it off, it will get harder when its like frozen cold i believe and easier to pop off without all the goo stuck on there
Edited by reg93f150
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
id use channel locks and pull like hell. have fun if its a good deadener you are going to have your hands full. and watch the foil it will tear you up with a quickness.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Factory installed sound deadener that is applied with heat (and typically lacks a foil top layer) can be removed chemically (not recommended) or by use of more heat OR extreme cold from dry ice as mentioned above. Either way you go at it, it's a mess and is time consuming.
If it's aftermarket sound deadener like Damplifier or Dynamat, as N8 suggested... pull like hell!
And I've found that if you pull on the material parallel with the surface it's applied to (vs. just pulling straight up on it), it comes off a little bit easier.
Have a question about Second Skin? E-Mail me!
Ok. Thanks guys
Nissan Frontier
10" Cadence Midbass
8" Cadnece Midrange
Bullet tweets
Mechman 270a
  • Who's Online   0 Members, 0 Anonymous, 2516 Guests (See full list)
