CleanSierra Posted October 24, 2012 Report Posted October 24, 2012 I'm at work reading the responses. The wiring for 1 ohm is wrong. You need all positives from all coils to positive on amp. Sane goes for negatives. I NOTICED alpine.... Im not the one you want to try to troll. Just a fyi for you.
Ryan929 Posted October 24, 2012 Author Report Posted October 24, 2012 36hz would give you good lows but get loud. Have someone on here build you a box. I dont think my truck has enough space inside without doing a blowthrough and id need money for that which i have very little of lol but this is a good idea
ALPINE408 Posted October 24, 2012 Report Posted October 24, 2012 I will post pics tomorrow when the sun comes out lol. And yes it is a prefab box only because i have a single cab truck and have hardly any room, I have also never built a box before and builing a wedge shape box seems kind of challenging... nor do i know of any box building programs really and i know that a bigger box that is ported would make it a lot louder which is why i was thinking about doing a blowthrough but i did stuff the box with polyfil i dont know if it actually helps or not but even if the box isnt huge and is a prefab shouldnt i notice a difference with adding that much more power and half the impedance. I also did double check the wiring i did positive on one voice coil to negitive on opposite voice coil on both subs and then took the positive on each sub and wired it to the amp and same for both negitives. Edit: Box is sealed and about 1 cubic foot per woofer lmao im dieing here everyone asked how its wired then when you reply with it and say its a prefab everyone jumps on about the prefab (yes they suck balls) but no one noticed that your wired to 4 ohms hahahhahahahaha Dude youre right.... lol i used this http://a248.e.akamai..._4-ohm_mono.jpg and didnt even notice it said 4 ohm load i thought it said 4 ohm subs.... lol thanks for pointing that out its all good im not laughing at you im loling at the replys wire it down you should notice a slight differnce it wont be much cause the prefab but ya try to figure out how to make a box even if its a sealed on do it to spec and will kick the shit out of the prefab Have you ever had your woofers blown?
Ryan929 Posted October 24, 2012 Author Report Posted October 24, 2012 Thank you guys for noticing even though i worded it very bad lol i will have to fix the wiring tomorrow and ill let you guys know if it makes a difference or not
Ryan929 Posted October 24, 2012 Author Report Posted October 24, 2012 I was going to upgrade my alt next but i guess ill save up for a box instead and hopefully ill notice a difference after that and ill measure it out and see exactly how much space i have behind my seat.
CleanSierra Posted October 24, 2012 Report Posted October 24, 2012 Which regular cab truck do you have? Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted October 24, 2012 Report Posted October 24, 2012 I was going to upgrade my alt next but i guess ill save up for a box instead and hopefully ill notice a difference after that and ill measure it out and see exactly how much space i have behind my seat. I'm TOTALLY for a blowthrough build, but you may have room to do a couple of 10s ported. Im not the one you want to try to troll. Just a fyi for you.
sbg Posted October 24, 2012 Report Posted October 24, 2012 Wiring is not right for sure! Dvc 4 ohm subs.. U have to put the + from one coil to the other+ on the sub to make the sub a 2ohm. When u do that to both subs then wire them together at the amp u get a 1 ohm 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Ryan929 Posted October 25, 2012 Author Report Posted October 25, 2012 Which regular cab truck do you have? I have an S10
Ryan929 Posted October 25, 2012 Author Report Posted October 25, 2012 I redid the wires and it made a pretty big difference I can only imagine whatd it sound like with the right box but this morning i was playing it and it blew my fuse after about 2 minutes of playing. It was a 60a fuse is this too small?
