First build. Metered 153.3db today. But something is wrong.
Wall is 20cu tuned at 33Hz w/ ~14 sq in per. 4 18" Level 3s on a BC5500d @ 1 ohm.
My peak was at 51Hz. Any idea on how to get a lower peak? I mean, how much lower can I tune, realistically?
I was told that a sub may be out of phase, but the wire is in the correct terminal...any other way to tell of one is out of phase?
Without even taking the peak into consideration...burping a 53 with my setup seems really low. I was hoping to do 52-53 on low music. Were my aspirations just completely unrealistic from the beginning?
Did a 146.8 at 35Hz.
-98' Ford Expedition (Rest in Peace)
-AVH-P3300BT
-Crescendo BC5500
-4 18" DC m2 Level 3.
What are you running?
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
Sorry. Forgot people are on mobile...everything is in my sig. 4 18" Level 3 m2s on a BC5500 at 1 ohm
-AVH-P3300BT
-Crescendo BC5500
are you sealed off?
you would have to pop the coils of each woofer. one could be mismarked or unhook all but one and see if its pushing out when its supposed to and pulling in when its supposed to etc. If you are not sealed off it should be your first priority.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Completely sealed off now. What exactly do you mean by pop the coils? Never done it
-AVH-P3300BT
-Crescendo BC5500
take a battery like 9v, wire + from batt to + on coil. - from batt to - on coil.
if sub moves up, then the polarity is correct. if the sub moves down, then the polarity is switched.
  • Who's Online   0 Members, 0 Anonymous, 1193 Guests (See full list)
