XS Power
Just a quick question about the charging voltage. I just bought myself a D3400 a couple days ago and I already love it even though I havn't even installed it! I was wondering what would be considered "OK" for charging the battery up. The charger I have is charging at about 14.6 and I know on the XS sheet it came with not to let it go above 14.4V +/- .3 for more than 5 minutes, should I just keep an eye on the charger or is it ok charging at 14.6?
2006 Ford Escape
Head Unit: Kenwood KDC 352
Subs: (3) 15" DC XL 15s with PSI recones, 1.4 ohm coils
Sub amp: DD Audio M4 (Black Version)
Door Speakers: (2) Crossfire 10s, (2) Hertz Coax.
Mid/highs amp: Rockford Fosgate P500-4
Electrical:
XS D3400 under the hood
(3) XS XP3000s in the back
2 runs of KnuKonceptz OFC 0 Gauge ran to the back (1 pos, 1 neg)
Excessive Amperage 300 amp alt (FINALLY!)
I don't know for sure but I think you'll be fine.. I've HEARD they say nothing over 14.7 or 14.9, then again I think Steve is at 15.3...
2003 GMC Yukon Denali
Alpine CDA 117
Redoing Mids/Highs
4 Runs of 1/0 Knukonceptz 2+, 2-
4 Deka 9A31's in back (Stock underhood) 250 amp Alt.
AQ20K
2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
He's talking about a charger, not alternator charging
Team Flex Issues
Sorry if I wasn't clear about it, yeah I was wondering about the charger voltage, though I was also going to ask about the voltage from the alternator as well. I've seen posts from XSpower saying not to go over 14.4 for both charger and alternator but i've also seen plenty of people running around 15.1 as well. Any other info would be great on this.
Edited by medley123
2006 Ford Escape
Electrical:
2.4v per cell for XS batteries
12v = 6 2v cells * 2.4 = 14.4v
14v = 7 2v cells * 2.4 = 16.8v
16v = 8 2v cells * 2.4 = 19.2v
Max sustained charge rates
This is to prevent gassing of the battery. I'm sure you can get away with more and still be "safe" but you could shorten the life of the battery - not to mention potentially void your warranty.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
