Parentnoia Posted November 5, 2012 Report Posted November 5, 2012 The vehicle is a 99 GMC C1500 Suburban. It has the stock L31/Vortec 5700 engine in it. Now, if I were to do the marine intake upgrade, would it have to use the same air intake? And what exactly would that improve? Also, I've been pondering an all together engine swap for the 454 option that came with the Suburban because I've always been told "There is no replacement for displacement." Now, the people that have told me that, are telling me that the 454 wont show an increase in HP, just torgue "and why do you need torgue if you're not towing anything?" So, pretty much, what options are out there to improve the performance without murdering mileage? A loss of 1 or 2 MPG is negligible. It's not like I'll be driving this thing on long trips unless I need to. 1999 GMC Suburban SLTNo system planned just yet. Look at "hate" spelled backwards. It spells "e-tah." For example, if you hate me you can e-tah dick.
OrionStang Posted November 5, 2012 Report Posted November 5, 2012 Dude, its a Suburban. Unless you go all out and add a couple hundred horses, you won't notice a difference. Bolt-ons will do nothing for a 5000lb truck, especially with the long gears its got. SMD Super Seller My Feedback Thread
79Bronco Posted November 5, 2012 Report Posted November 5, 2012 Give up all hope on going fast in that thing. Source: Parrot Asteroid Smart Processor: Digital Designs X1 Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400 Front stage: Hertz 165xl + HL 70 + HT28 Rear fill: Hertz 165xl Subs: 2 SA-12's 3-way active ftw
Parentnoia Posted November 5, 2012 Author Report Posted November 5, 2012 Dude, its a Suburban. Unless you go all out and add a couple hundred horses, you won't notice a difference. Bolt-ons will do nothing for a 5000lb truck, especially with the long gears its got. I cant even find any bolt-ons for the damn thing. And it's not like I'm trying to turn this thing into a 10 second truck or anything. I just know that when I start on the audio, the weight is going to kill what power it does have. 1999 GMC Suburban SLTNo system planned just yet. Look at "hate" spelled backwards. It spells "e-tah." For example, if you hate me you can e-tah dick.
WICK3DxGATA Posted November 5, 2012 Report Posted November 5, 2012 there really isnt much for performance for that 5.7 unless you want to get down to cam and heads or some sort of air induction. and i would think you would see quite a big hp gain from the 454 and the extra torque would help anyway with the weight of your vehicle especially if your planning on doing a big system in it. 99 Gmc sierra extended cab front speakers: DB drive 6.5 back speakers: DB drive 6.5 amp: none right not subs: none right now Future waiting to get my 2 skar vvw 8s installed
Parentnoia Posted November 5, 2012 Author Report Posted November 5, 2012 there really isnt much for performance for that 5.7 unless you want to get down to cam and heads or some sort of air induction. and i would think you would see quite a big hp gain from the 454 and the extra torque would help anyway with the weight of your vehicle especially if your planning on doing a big system in it. On that note, all my research into cam upgrades doesnt come to much fruitation. I can find that it can be done, but can never find where to get said parts. 1999 GMC Suburban SLTNo system planned just yet. Look at "hate" spelled backwards. It spells "e-tah." For example, if you hate me you can e-tah dick.
WICK3DxGATA Posted November 5, 2012 Report Posted November 5, 2012 there really isnt much for performance for that 5.7 unless you want to get down to cam and heads or some sort of air induction. and i would think you would see quite a big hp gain from the 454 and the extra torque would help anyway with the weight of your vehicle especially if your planning on doing a big system in it. On that note, all my research into cam upgrades doesnt come to much fruitation. I can find that it can be done, but can never find where to get said parts. comp cams makes some good ones for the 5.7 along with thunder racing and sdpc also have great cams. but replacing cams you must also replace things such as pushrods, valve springs, lifters, timing chain and possibly other parts. 99 Gmc sierra extended cab front speakers: DB drive 6.5 back speakers: DB drive 6.5 amp: none right not subs: none right now Future waiting to get my 2 skar vvw 8s installed
94jettameowpsst Posted November 5, 2012 Report Posted November 5, 2012 Unless you're trying to cut into the motor you're not going to gain much. High compression pistons, head work, cams, intake, exhaust, chip/increase timing, tune. Ud probably just be better off swapping the motor for something bigger 150.1 @ 38hz142.3 @ 20hz (windows down)Only 2 batteries
1996BLKBauer Posted November 20, 2012 Report Posted November 20, 2012 I've tried the whole, more HP/MPG thing on my SUV, unless you spend huge amounts of $$$$, it isn't worth it, even then, it's not worth it. 1996 Ford Explorer Eddie Bauer V8 AWD So far with the Ford/JBL Stock Stereo system, Alpine System coming soon.
stevensracing06 Posted November 20, 2012 Report Posted November 20, 2012 Burbs are low and slow or high and slower lol there isn't any fast about those things
