donberto Posted November 9, 2012 Report Posted November 9, 2012 Probably a dumb question but here goes, I know the difference between 1, 2, 3 and none my question is how does it affect tuning. I was using the torres calc. and would get optimum tuning and net volume and then when I put 3 in common walls it changes tuning quite a bit. Even did width of port by 3/4 for plywood by length to figure out displacement of wood and .14 for the level 2 12 and can't get the numbers to jive. Still going to build it per cut sheet just wondering.
donberto Posted November 9, 2012 Author Report Posted November 9, 2012 also the speaker and vent are on the same side do to space problems, will it affect sound?
shogen Posted November 9, 2012 Report Posted November 9, 2012 Waiting for input... Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
Jessica Posted November 9, 2012 Report Posted November 9, 2012 the port for a 3 common wall will displace less air in a box than a 2 common wall and 2 common wall will displace less than a 0 common wall. look at the 3 common wall box, it uses only one wall or board, where a 2 common wall box uses 2 pieces and 1 common wall uses 3 pieces, 0 uses 4 pieces. So typically if you are a tight space requirement you uses as little wood as possible to make the port. when you change tat field in torres it changes your port displacement, and your net volume and your port ratio and your tuning. like a domino effect. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
donberto Posted November 9, 2012 Author Report Posted November 9, 2012 i think i figured it out on my own. 3 common uses the side which cut down on displacement for plywood. if you have a four sided port in the box you have to account for that displacement which changes the net volume thus changing the tuning, i think
Guest Posted November 9, 2012 Report Posted November 9, 2012 3 means the port is touching 3 walls. 2 means the port is touching 2 walls. 1 means the port is touching 1 wall. 0 means the port is touching no walls.
shogen Posted November 9, 2012 Report Posted November 9, 2012 3 means the port is touching 3 walls. 2 means the port is touching 2 walls. 1 means the port is touching 1 wall. 0 means the port is touching no walls. Okay.... possible diagram? Or example of a 3 and 2? Please... Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
Joe X Posted November 9, 2012 Report Posted November 9, 2012 Okay.... possible diagram? Or example of a 3 and 2? Please... The Torres help provides links to each to pics of each case. Here they are: 1 - Port with 0 common walls: http://img693.imageshack.us/img693/6474/independentport.jpg 2 - Slot port with 1 common wall: http://img341.imageshack.us/img341/9939/bottomportbox.jpg 3 - Slot port with 2 common walls: http://img94.imageshack.us/img94/2017/middleportbox.jpg 4 - Slot port with 3 common walls: http://img246.yfrog.com/img246/6968/slotportbox.jpg
shogen Posted November 9, 2012 Report Posted November 9, 2012 Okay.... possible diagram? Or example of a 3 and 2? Please... The Torres help provides links to each to pics of each case. Here they are: 1 - Port with 0 common walls: http://img693.imageshack.us/img693/6474/independentport.jpg 2 - Slot port with 1 common wall: http://img341.imageshack.us/img341/9939/bottomportbox.jpg 3 - Slot port with 2 common walls: http://img94.imageshack.us/img94/2017/middleportbox.jpg 4 - Slot port with 3 common walls: http://img246.yfrog.com/img246/6968/slotportbox.jpg Thank Joe. I know you know boxes. Glad you chimed in. Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
RooTxBeeR Posted August 31, 2016 Report Posted August 31, 2016 Okay.... possible diagram? Or example of a 3 and 2? Please... The Torres help provides links to each to pics of each case. Here they are: 1 - Port with 0 common walls: http://img693.imageshack.us/img693/6474/independentport.jpg 2 - Slot port with 1 common wall: http://img341.imageshack.us/img341/9939/bottomportbox.jpg 3 - Slot port with 2 common walls: http://img94.imageshack.us/img94/2017/middleportbox.jpg 4 - Slot port with 3 common walls: http://img246.yfrog.com/img246/6968/slotportbox.jpg Hey joe, would you happen to have access to those picture so I can download for refence? On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
