nightshadelove Posted November 12, 2012 Report Posted November 12, 2012 i got a sundown sae 1200d, running all zero gauge with a kinetik hc 800 in the back. today was playing a song i didnt know and it started out really quiet so i turned it up, then blast the music then the amp cut out. now my amp will turn on for a few seconds depending on the volume then go to protect for around 5 seconds then back on and repeat. i've read to check all grounds which mine seem fine. then heard something about the fets. not sure what to do...hope its not blown..
BobbyG2 Posted November 13, 2012 Report Posted November 13, 2012 What are your subs wired to? The SAE 1200D doesn't like less than 1 ohm resistances. *New vehicle and system coming soon.*
Raptorman Posted November 13, 2012 Report Posted November 13, 2012 What voice coil configuration are your sub(s)? 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
BobbyG2 Posted November 13, 2012 Report Posted November 13, 2012 Oh, and it doesn't like more than 15v electrical too. What's your electrical like? Do you have a volt meter connected to your amp that you can tell us the voltage? *New vehicle and system coming soon.*
nightshadelove Posted December 11, 2012 Author Report Posted December 11, 2012 i am running a sundown z15 psi recone.. kinda beefed up and its dual 2 ohm but it sits at around 1.7 ohms or something, i ended up opening the amp up and checking out the inside. ended up being a fet blew loose and the ground inside blew loose. sodered it up and have been beatin since with no problem! thanks tho!
