sundown sae 1200d problem
nightshadelove
i got a sundown sae 1200d, running all zero gauge with a kinetik hc 800 in the back. today was playing a song i didnt know and it started out really quiet so i turned it up, then blast the music then the amp cut out. now my amp will turn on for a few seconds depending on the volume then go to protect for around 5 seconds then back on and repeat. i've read to check all grounds which mine seem fine. then heard something about the fets. not sure what to do...hope its not blown..
What voice coil configuration are your sub(s)?
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Oh, and it doesn't like more than 15v electrical too. What's your electrical like? Do you have a volt meter connected to your amp that you can tell us the voltage?
*New vehicle and system coming soon.*
  • 4 weeks later...
i am running a sundown z15 psi recone.. kinda beefed up and its dual 2 ohm but it sits at around 1.7 ohms or something, i ended up opening the amp up and checking out the inside. ended up being a fet blew loose and the ground inside blew loose. sodered it up and have been beatin since with no problem! thanks tho!
  • Who's Online   0 Members, 0 Anonymous, 703 Guests (See full list)
