kirill007 Posted November 18, 2012 Report Posted November 18, 2012 You can easily google what Ah means.. Ah=AmpHour, which means how much hours a battery can last if you draw 1 amp from the battery. So 70Ah= 70 hours if you draw 1 amp or 35hours if you draw 2 amps or 7 hours if you draw 10 amps and so on. The higher the better, but a high Ah rating is only good if you want to use the stereo when the engine isn't turning. For car audio you would want a low resistance battery with a high maximum continuous discharge current and a high maximum 30-sec discharge pulse current but not a lot of manufacterers put up this info. So you'll find Ah and CA(= cranking amps) and sometimes RC (Reserve Capacity, is a battery industry rating, defining a battery's ability to power a vehicle with an inoperative alternator or fan belt. The rating is the number of minutes a battery at 80 degrees F can be discharged at 25 amps and maintain a voltage of 10.5 volts for a 12 volt battery. The higher the reserve rating, the longer your vehicle can operate should your alternator or fan belt fail.) High CA and high RC= very good, a high Ah is only a bonus for car audio. Thinking is the root of all problems... You ALWAYS get what you pay for.
BassMunky Posted November 19, 2012 Author Report Posted November 19, 2012 soo in that case im gonna get a diehard platinum battery for the back on black friday and wanted suggestions on what extra battery i should get thanks i have a diehard platinum up front group 35 with a 100.4 sundown and a rf 1500bdpc. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Watch the bass Posted November 19, 2012 Report Posted November 19, 2012 Good offer but idk the shipping to Hawai http://www.stevemeadedesigns.com/board/topic/144556-dont-seem-like-a-bad-deal/ "in the abundance of water, the fool is thirsty" Bob Marley
BassMunky Posted November 19, 2012 Author Report Posted November 19, 2012 will the diehard platinum group 34 be ok for a extra battery? these ones or which is better. http://www.sears.com...134000P?prdNo=1 http://www.sears.com/diehard-platinum-automotive-battery-group-size-75-86dt-price/p-02850080000P?prdNo=49 http://www.remybatte...tery-P9239.aspx Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted November 21, 2012 Author Report Posted November 21, 2012 bump Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted November 23, 2012 Author Report Posted November 23, 2012 bump Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
8ight Posted November 23, 2012 Report Posted November 23, 2012 Can you get anything from East Penn in Hawaii? Otherwise your choices are pretty restricted, but I know people getting loud on Walmart batteries so let your wallet choose, I suppose. I'm gonna hate
BassMunky Posted November 27, 2012 Author Report Posted November 27, 2012 what that man Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Tim Lam Posted November 28, 2012 Report Posted November 28, 2012 go with Kinetik or xs power if you can get a hold of them! kinetik hc2400 are popular, as well as xs power d3100
BassMunky Posted November 28, 2012 Author Report Posted November 28, 2012 another other brands equalivent to like diehard or optimas. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
