sbg Posted November 13, 2012 Report Posted November 13, 2012 Ok I see now, I'm on my cell and its kinda slow 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
ALPINE408 Posted November 13, 2012 Report Posted November 13, 2012 Well if its a 500d or something then he just needs to go up to a 80 or 100 amp in that holder , but I don't see what size amp he has, only that its a Rockford. I have the Rockford Fosgate T1500-1bdCP good god rip all that wire out to much power not the right wire and up it to a 200 ANL fuse Have you ever had your woofers blown?
sbg Posted November 13, 2012 Report Posted November 13, 2012 For sure need 0ga , big 3 and the works for that amp! I think they do like 1800+ rms 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Deven Parent Posted November 13, 2012 Author Report Posted November 13, 2012 Can someone give me a list of what I need to do to get this system on its feet. I love the comments from all of you, but it becomes very confusing when 2 or 3 people are telling me different things. Thanks ahead of time for the help. My trip to Meades shop - http://www.stevemeadedesigns.com/board/topic/172904-could-i-come-for-a-visit/ My vid at Meades shop - http://www.youtube.com/watch?v=YxinD-xwWWo Had an amazing time bro! Die hard Meade fan! -- My System -- 2001 Hyundai Tiburon -- (1) Rockford Fosgate 1500.1bdCP (1) Rockford Fosgate 360.3 (1) Pioneer GM-D9500F (1) Optima Yellow Top D34/78 (2) Pioneer TS-W3002D - 1000W RMS 12's (1) iPhone 5s - 32gb White (1) iPad Mini - 16gb Black ( 24/7 Headunit ) -- Wanted Upgrades -- (2) SP4 (15's or 18's) (1) BC5500 (1) Mechman 320 amp Alt (4) Optima Yellow Top D34/78 (1) Big 3 Upgrade Kit Fix my other T1500.1bdcp
alaskanzx5 Posted November 13, 2012 Report Posted November 13, 2012 Well if its a 500d or something then he just needs to go up to a 80 or 100 amp in that holder , but I don't see what size amp he has, only that its a Rockford. I have the Rockford Fosgate T1500-1bdCP good god rip all that wire out to much power not the right wire and up it to a 200 ANL fuse thats what im saying. this says fail with a topping of car electrical fire all over it. the t1500.1bdcp manual says 200amp fuse and has 4 gauge inputs. get an agm battery run 1/0 from front to rear batt. run 4gauge from rear bat to amp. fuse no less then 6" away from the rear battery between the amp and battery. then you should fuse the 1/0 wire going from front to back. if im not mistaken 1/0 is rated for 300amps, match the wires amperage rating to a fuse for that wire. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
sbg Posted November 13, 2012 Report Posted November 13, 2012 For sure need 0ga , big 3 and the works for that amp! I think they do like 1800+ rms shit he still going to get bad volt drop even with good wire, even if He has 2 battery's, dude u need a good alt! 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
ALPINE408 Posted November 13, 2012 Report Posted November 13, 2012 list 1/0 wire front to back power distro block ground distro block 1/0 ground 200 amp ANL fuse do BIG 3 upgrade if you have money for it a second batt in the trunk Have you ever had your woofers blown?
ALPINE408 Posted November 13, 2012 Report Posted November 13, 2012 For sure need 0ga , big 3 and the works for that amp! I think they do like 1800+ rms shit he still going to get bad volt drop even with good wire, even if He has 2 battery's, dude u need a good alt! not really do my list first then if you feel you need it up grade the alt at a later time also add to the list a Voltage meter there not the best but you can get a stinger digital voltage meter for around 15 bucks to keep an eye on your voltage Have you ever had your woofers blown?
pa-pa-platypus Posted November 13, 2012 Report Posted November 13, 2012 list 1/0 wire front to back power distro block ground distro block 1/0 ground 200 amp ANL fuse do BIG 3 upgrade if you have money for it a second batt in the trunk ^^ right here he may know a thing or 2 This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
n8ball2013 Posted November 13, 2012 Report Posted November 13, 2012 that fuse would definitely be the problem. 60 amps aint getting you much out of a t1500. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
