my car wont stay idled
Are the valves not sealing properly or are they just simply not working? This could just be a valve adjustment is needed, but if they aren't working at all then. That could be a major valve-train issue.
Also, honda's have this cool little device called an ELD lol. If it has gone bad this will basically kill the power that is being supplied from the alternator which would cause these funky problems like a misfire or a rough idle until something causes the alternator to kick on because the engine is not being supplied the right voltage. I would check your voltages while idling and while revving the engine. I don't know for sure but it is worth a shot.
edit: What engine is in the civic?
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
a d16y7 the stock engine, and that valve is just simply not working, bc there is no idle change when i remove that spark plug wire
Could be an injector not working.
Could be the wiring to the injector.
Could be the spark plug not working.
Could be the spark plug wire.
There may be one of several things not working but you'll have to try and test each one.
You need to try and do a process of elimination to narrow the search to the actual cause.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Fitv? Check that
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
I had an issue that sounds exactly like this one in my Pontiac. Could figure the issue out cuz I was extent focused on mechanical. It ended up being a bad wire, might want to look into that too.
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
i dont have any audio stuff in my civic yet..
and skullz i have new wires, new spark plugs new distributor cap.. it was doing it before i switched all this stuff out, but i may need some new fuel injectors, so i cant go see my mechanic until monday since he has 2 projects already..
so im just trying to find a process of elimination lol
and Vette tell me what u mean by FITV??
FITV is the fast idle thermo valve. Common issue with Hondas with the SUGRING idle problem that you DO NOT have.
Read the complaint people b4 you post. This was already brought up 3 timers prior...
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
Me neither. Stock wiring went bad.
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
So many things. Fuel pressure regulator, vacuum line(s), TPS is off or the throttle cable needs replaced, etc. These are a mechanics dream. Find a good one or it will be, it's this, or this, well maybe it's this...Ok I got it this time it's this. 1k later...
How does it start? Do you have to crank it for a few seconds? If so, then it is more than likely fuel related as in too much. (Sorry if I missed that if you said it already.)
10501650_10203332501847103_1859383749711
Blown
