I recently picked up a 01 Yukon, the headliner was trashed so figured i would go ahead and refinish it. I pulled the headliner out and started pulling off the old material as i'm doing so i say to myself self this is coming off to easy and low and behold it was, i mistakenly pulled off the layer of fiberglass that covers the foam material along with the cloth. My question is can i still use this with the new covering? will the adhesive stick to this or am going to need to buy a new shell? As always any and all help will be greatly appreciated thanks .
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
i pull off the old foam as well. get a wire brush and go to it. then make sure you buy hte headliner material with the foam already attached to it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I removed all the old material but the the actual headliner shell in these isn't like the older cars it's made of a foam center sandwiched between two very thin pieces of what look like fiberglass board, the cloth, vynal what have you get's glued to this board but when i removed the old cloth material this thin layer of fiberglass came up with it, i'm just not sure if i can glue anything to this not sure it will adhere.
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
as long as its still rigid you should be fine.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
It's still rigid just seems a bit on the brittle side, i'm wondering if should try and reinforce it somehow? Not real sure what to use.
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
will give it a try thank's guy's.
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
