Help! Need a little wisdom about black voice coils please
FeelDaBass
Hi, I recently purchased a used Rockford t0 15" off of eBay and the coils on it are black as black can be. The resistance is about normal as it is a dual 4 ohm sub and sits at 7.4 to 7.6 (I believe it was) at 8 ohms, and 2.2 at 2 ohms. The subwoofer is pretty stiff but does move without any scratchy noise/feeling. Is the sub perfectly fine? Are these coils different than others(black)?
The previous owner claims that he ran the sub with a Hifonics Brutus amplifier, 1100 watts at 1 ohm, which is 800 at 2 ohms in a prefab ported box. The sub has a rated 800 watts rms.
Any input at all would be greatly appreciated!!
'98 Chrysler Concorde LXi
Pioneer DEH-80PRS (HU/processing)
Rockford Fosgate T1652-S (components) for front
Rockford Fosgate T1693 (6x9s) for rear
Rockford Fosgate T600-4 running those
Rockford Fosgate T1500-1bdCP running a
Rockford Fosgate T1D215 15"
in a 3.1 cu ft. net tuned to 34 hz (firing in cabin)
Kicker PKD1 (0 & 4 AWG)
stock 130 amp alt for now; One yellow top Optima
Installed everything myself & built box (brother helped)
Used a DD-1 to set gains.
Build Log: http://www.stevemeadedesigns.com/board/topic/165894-first-build-accumulated-since-i-was-14/
Just Pics: http://www.stevemeadedesigns.com/board/garage/vehicle/1463-chrysler-concorde-lxi/?tab=images
Actually, I think the 8 ohms was more like 6.8 ohms.
Some subs have black coils. My level 5 came with black coils, and the SP audio subs have black coils too. Straight from the factory
Now I'm not sure if those should be amber or not... But I'd think that if the coils each read what they are supposed to, the coil isn't "bubbly" and it doesn't scratch, you should be fine.
I didn't think about measuring them individually since RF made the quick and easy parallel to series. I'll try that next weekend when I can. Thank you.
  • Who's Online   1 Member, 0 Anonymous, 512 Guests (See full list)
