2000 Integra, Rockford Components, U.S Amp, Alpine Amp, Shok Flo-1k, KnuKonceptz
I've never seen/heard of Pioneer that clips under 50. I don't think I've ever seen one clip under 55 actually
that would probably help explain why all there hu's are rated at 14 watts rms per channel unlike others at 20+
the enternal amp would have nothing to due with the rca outputs clipping. the enternal amp would only effect speaker ran of the hu.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
well small update, finally got the deck installed and sounds great! cant wait to get my speakers hopefully next week and an amp when i get paid next week!
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
2 15s 4inch coil psi recones temp til my subs are reconed
Focal P165-v15
Audison voce quattro
fully active
Only gonna get louder
146.1 at 38hz
138.x at 24hz
Build log
http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
took apart the whole centre console.
fitted the mounting kit, really nice quality, xscorpion brand.
soldered the main wires, sense im not going to be using the other ones in just a little bit ;)
oh and mounted it all inside
did some work on the box today, cleaned up the holes a little more and glued down the second baffle
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
i lied, speakers should be here tommorow as theyve already passed the border and are only about an hour away!
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
Looking good!!!!!
thanks! cant wait to see how amazing those t1's sound compared to these shitty oem ones
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
You should go grab a flipout storage din from a junk yard. I did that in place of the aftermarket kit. I believe I got mine from a Nissan or Toyota. Looks good though!
95 Acura Integra - 5-speed
Pioneer FH-X700BT
(2) Rockford Fosgate 12" P3
AQ1200d
Rockford Fosgate P1652-S 6.5" components
Rockford Fosgate P1572 5x7"
Rockford Fosgate R400.4
95 Integra Build Here
93 EJ2 Build Here
Kind of hard to explain so I went ahead and took a picture of mine.
Like I said, grabbed it from another import of some sort at the yard (actually 2-3 different ones) then I got the metal holder that holds the headunit and fit it in that way.
Pioneer FH-X700BT
AQ1200d
93 EJ2 Build Here
