3200rms for $220 bucks
Cuseikan
I thought the brutus line "BRZ" was the only hifonics line that was worth a damn? Maybe i am wrong.
no your right but his amps a spl brand
this amp your looking at might be able 2 do the power it says, but how clean do u think it will be?
**actin bad like a kid at six flags**
With 150 amps in fuses, the voltage he would need is:
21.3 volts with 100% efficiency (Physically impossible)
23.9 volts assuming 88% efficiency (Random number since I couldn't find anywhere where it listed it's efficiency)
So, basically, no way in hell would it put out 3200watts. Dirty or Clean.
*New vehicle and system coming soon.*
so you take the fuse rating and multiply the voltage to get to the wattage?
subtract 20% from that and you should be close.
edit
Look at the sundown 1500.1, 150a fuse rating, 14.4v =2160 - 20% = 1760.
And the sundown 1500.1 will do 1700ish watts
If you do the same calculation with these type of amps you have to consider they are a lot less efficient then quality amps.
So you can easily substract 30%, even 40%.
So you would get around 1300W-1400W, and that's probably when you will be clipping the amp.
It's junk, stay away from it and buy something that will last, be reliable and take a beating.
If your wanting north of 2k than your going to spend close to $400 for some something capable, reliable and able to do it without going up in smoke after a month or two.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Here's what I'd recommend for north of 2k watts for cheap:
BRZ2100.1: $300
http://www.wooferset...-amplifier.aspx
Crescendo BC2000D: $380
http://store.soundso...-amplifier.html
BRZ2400.1: $400
AQ 2200D: $430
http://www.audioque....ifier_p_31.html
Or search the FS section.
That 2100 is $260 on Sonic ;)
http://www.sonicelec...BRZ2100.1D.html
Also the 2400 is $275
http://www.sonicelec...BRZ2400.1D.html
Not bad, a little overrated, but still 2500-2700 watts.
  • Who's Online   0 Members, 0 Anonymous, 1007 Guests (See full list)
