Trey_Dog650 Posted November 28, 2012 Report Posted November 28, 2012 the dust cap? just put some type of clear silicone or something get an image hosting site like photobucket. upload pics there. copy img code and paste it here in the txt. 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
3410Sergioooo Posted November 28, 2012 Author Report Posted November 28, 2012 Yeah. And I'll get back at you tomorrow with the pictures.
purplesyrup Posted November 28, 2012 Report Posted November 28, 2012 duct tape, it will be good ass new, but really, not firmiliar with your sub but sounds like you need to do a rocone , if the crack is really bad and getting worse it will likely cause damamge to the VC if things start to move or flap un evenly due to a drastic crack in the cone from seperation just my educated guess but what ever you do, it will likely be more rewarding to fix it right the first time rather than doctor it up when the results will likely be only a temporary fix until the sub is no longer playable
SnowDrifter Posted November 28, 2012 Report Posted November 28, 2012 Strip of fiberglass over it? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
3410Sergioooo Posted November 28, 2012 Author Report Posted November 28, 2012 I have duct tape on it right now. A lot if it. I used some LBJ glue to put on it and it worked but I stell needa do some about the edge where the foam part is at cause it didn't glue on there. The glue turns into plastic after it dries up. Edit: JB weld glue
Tebo Posted November 28, 2012 Report Posted November 28, 2012 Go to Home Depot and buy goop. It's with all the other glues an epoxies. Put the good on the "foam part" sorround to repair that. I would put a layer on both sides of the foam. Still need those pics tho... 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
Guest Posted November 28, 2012 Report Posted November 28, 2012 if its on the dust cap, just use CA glue. nuff said.
bighossf150 Posted November 28, 2012 Report Posted November 28, 2012 I wish I had an amp strong enough to.crack a dust cap. What was it? A boss? Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
