jhaffey93 Posted November 29, 2012 Author Report Posted November 29, 2012 Scroll to the relay it shows a good way... There are a few out there let me look http://www.stevemead...9-done-vid-pg2/ can you give me the wiring diagram for how you wired in the relay to that distribution thing?
ChevyBoy95 Posted November 29, 2012 Report Posted November 29, 2012 You will need a 5 pin relay. pin 30 - constant positive (or battery positive) pin 85 - coil ground (or battery negative/frame ground) pin 86 - coil power (or headunits remote turn on that usually goes to an amp) pin 87 - switched (or positive 12v power output aka this goes to all the devices you want to turn on) pin 87a - dont use Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
captainhook426 Posted November 29, 2012 Report Posted November 29, 2012 The batteries act as a reserve for the alternator if your accessories and amps us 150 amps combined then when you run full tilt your batteries are going to be responsible to supply 45 amps to supplement the system to run at that level for how ever long you run it at. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
KenC210 Posted November 29, 2012 Report Posted November 29, 2012 You will need a 5 pin relay. pin 30 - constant positive (or battery positive) pin 85 - coil ground (or battery negative/frame ground) pin 86 - coil power (or headunits remote turn on that usually goes to an amp) pin 87 - switched (or positive 12v power output aka this goes to all the devices you want to turn on) pin 87a - dont use A 5 pin is not necessarily needed you could find a cheap relay at radio shack http://www.radioshack.com/product/index.jsp?productId=3020762&retainProdsInSession=1&znt_campaign=Category_CMS&znt_source=CAT&znt_medium=RSCOM&znt_content=CT2032230 Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
ChevyBoy95 Posted November 29, 2012 Report Posted November 29, 2012 You will need a 5 pin relay. pin 30 - constant positive (or battery positive) pin 85 - coil ground (or battery negative/frame ground) pin 86 - coil power (or headunits remote turn on that usually goes to an amp) pin 87 - switched (or positive 12v power output aka this goes to all the devices you want to turn on) pin 87a - dont use A 5 pin is not necessarily needed you could find a cheap relay at radio shack http://www.radioshac...ntent=CT2032230 true, but it is easy to get hold of a 5 pin and a 5 pin harness for a few bucks. but the link you posted is a perfect one that doesnt have the extra 87a for confusion. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
