the sd-2 12 goes for $160 on ebay
http://www.ebay.com/...=item19ca06a5ee
solid. what can be compared to an sd 12 in performance taking into consideration that its running rms at the recommended sealed enclosure size?
Why go slim? Also, you say your ona tight fit, so a single 12, which I am guessing you can only go sealed with that, so 1cu. A single 8 ported is around the same as that, with more than likely, higher output. Check out Skar audio's B-stock sale and see fit hey have anything there for cheap
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
that chart also say the w3 did 109 db . you also dont know how much power was put to the sa-12 . it says 500w for the w3 which is near its max
REP
1 cubic foot sealed with the amp you have run it at 2 ohms your amp should give the rated power for the sub its 500 rms but here are the specs
Fs: 38.8 Hz
Re: 8.0 ohms
Qms: 6.18
Qes: 0.69
Qts: 0.62
Cms: 0.09 mm/N
Mms: 195 g
BL: 23.5 NA
Vas: 31.7 L
Sens: 86.1 dB 1w/1m
Le: 4.14 mH
RMS: 500 watts
SD-2 12
Sealed 1 ft^3 Ported 2 ft^3 Displacement 0.10 ft^3 Depth 5.25" Outside Diameter 12 5/8" Cut-Out 11 1/8"
SD2's sound and perform REALLY nicely sealed also.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
  • Who's Online   0 Members, 0 Anonymous, 1115 Guests (See full list)
