DC Sound Lab
Ripping it out ? Pics of said baffles
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
As brutal as that thing is now, I would cut 4 more holes in the baffles you have now and give that a shot first. Damn thing gets nasty in the mid 20s!
Yea im gonna try it out, and try to seal off the rear ports to see how it sounds as a 4th order
Turning it into a 4th could potentially be nasty. Depending how you seal off the rear ports, you shound have 5-6ft3 per side which is perfect for the XLs. Could really be nasty!
