Torres Posted December 23, 2012 Report Share Posted December 23, 2012 ponte is thinner and will soak up less than fleece. but also a tad more expensive. also, i'd look into CA glue Link to comment Share on other sites More sharing options...
jdw46 Posted December 23, 2012 Report Share Posted December 23, 2012 I used speaker grill cloth (bc its so thin) for the shell then laid chopped mat behind it 2000 stratus10 SunDown E-10s Singer 250amp Alt Xs Power D975Concept c2400All 0 gauge wire10 6 1/2's in Rear Doors Link to comment Share on other sites More sharing options...
kingsuv Posted December 23, 2012 Report Share Posted December 23, 2012 I use the cheap air stapler from HFT and the hand one from Arrow. Both will get the job done. If you are going to cover the whole door then you can use the 3m spray glue. Spray it on bot sides and let it tack up. I use fleece and spandex depending on what i am doing. The spandex is great for hard to shape areas but is thin so may sag when spanning long areas. For those spots i do a very light skim over the material so it gets a light crust, then do a few more light coats until its strong. Then do some cloth under it for strength. I always try to make my cover the top coat. Always try to work the strength build up under what you want it to look like. It saves a HUGE amount of sanding. If you do it right, you will save a ton of time and the product will have a better result. Lastly, good products is key. Don't cheap out on materials. redoing something because it turned out like ass is more expensive then taking the time and money to do it right Designing, building, and shipping boxes. Yahoo IM - kingsuv00If the listening level is too loud, please inform the driver, so he can promptly pull over, and let you out. not many cars can get me to pluggin my ears but this one.......damn. I mean the first minute is ok but that thing just really starts digging deeper and deeper in your earhole till you cant stand it no more. Seems like it does it with relative ease....16 12's on 8 amps.........gotta love it. Link to comment Share on other sites More sharing options...
Smoove Posted December 23, 2012 Report Share Posted December 23, 2012 Do you glass over the vinyl on door or peel it off? 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
