Loud & Low 8th Gen Civic - Time to say good bye to her.
expanded metal shouldn't make noise. I was going to use some myself. Just make sure the metal part is as thin as you can get. more air less metal and you are good
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Good to see your secret plans are coming together.
Should simplify things a bit. :peepwall:
At first look your list don't look so bad, but as I scroll down I was like damn thats alot to get done.
It's like rubbing your wiener up against a sheep.
Ok I just pm'd you. I was originally going to use those too. Glad I didn't now, cause it'd have been a horribly tight fit. I could've made it work, yes, but it would've looked jammed in there. I like how these came out. WE'll talk man. Gonna be a bit before I'm ready to do anything.
Just about off folks. Gonna run a couple errands and head home and do something! Not sure what, but I'll do something. lol
for sure man and the reason why i am gonna use them is because of the carbon fiber look plus my door the outer grill is the same size as 8 inch speaker
2010 Mazda 3
*Rebuild Time*
Subs - (2) AA Mayhems 12's
Sub amp - (1) Populus Audio TPA 6500
Headunit - Pioneer App Radio 2
Batteries - XS Power (1) D3100 up front | 6 XP950 rear
Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1
Alternator - Singer 260 Externally Regulated
Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors)
Mids & high Amp : (2) Populus Audio 100.4
Processor: Rockford 3sixty.3
The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
I'm more excited to see this build finished than the new amp I just put in mine today!! Amazing work as always scooter!!
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
Thanks for the great deal on the amps bro. I'll have my build up by March
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Thanks guys. Yeah it's a longer list than I thought. But partially my own fault since I threw the doors in there.
I did go out and put the baffle in though. There's between 90-100 3" screws all around it into the enclosure body. Hopefully that's enough.
So subs are next to go in, but I had to do kid duties tonight cause my wife isn't home from work till later. She had to work ot. So I should have those in tomorrow night, and hopefully they will be wired up and the amps wired up by the weekend. Sooo much to do.
We'll just have to see what happens.
Well damn it guys. I went to load the subs tonight, and it's a no go. I forgot that these subs have a direct lead, which is great, but it's short cables, and I don't want to splice. So I have to figure out how to desolder these and solder the new SHCA 8ga on to them.
I did manage to get some other stuff done. SO I guess it wasn't a total loss. We'll see if I can get anything done tomorrow. Man this hill is getting steep!!
Are the leads too short to do threaded rod/bolts on the box? I'm not sure if you consider that splicing, but I guess the best would just be strait to the amps. I only bring that up because thats the rout I'm taking when wiring my subs up. Good luck!
Funny how the people who have a louder system than you will usually give you a compliment about your setup because they know how much blood, sweat, time, and money you put into it. The people who criticize or try and one up you....have a p.o.s to no system at all and will tell you all about this "other" guys system! Saddley I'm sure if I meet this "other" guy...he will probably tell me he thinks your just as annoying as I think you are!
I'm not compensating, just proud of fabricating!
My build log: 10k center console with 4 DC Audio XL 10's powered by 2 DC Audio 5.0k amps 5 xs batteries and dual DC Power 300xps alts
http://www.stevemeadedesigns.com/board/topic/169404-goodvibez-04-dmax-10k-center-console-w4-xl-10s-custom-5ksit-plays/page-19
They make copper crimp connectors with integrated heat shrink surrounds. I know this is a splice, but it is a good temp solution, or permanent. Desoldering can be a pain.
And a good connection of 8 gauge is more than enough to handle the power duties.
I understand being particular, but I wouldn't let it hold up the build, especially when it can be so easily replaced later, if ever
Yes I have a lot of stereo weight. I build for Smiles Per Gallon not Miles Per Gallon LOLZ
My build - 1996 4Runner with 2 18s - 149+ in a sealed box (with radiators)
0a4ee87c-28c8-4bf8-9dfe-5a06b9dea2dc_zps
3e3eb9dd-70f8-4424-ad11-ccebcd929ac4_zps
  • Who's Online   0 Members, 0 Anonymous, 1676 Guests (See full list)
