I can't take it anymore *Need Black Rims*
Duplicolor has some NICE spray can colors and kits for wheels.
Retired from SPL again....
2016 IASCA Truck/Trunk 2 Champion 151.8db
2016 IASCA Truck/Trunk 2 World Record Holder
Yes, I got them painted. I'm fairly pleased with the look. But in terms of durability: nothing beats a good powdercoat. Pretty much this stuff will last until I get new tires, but it won't hold up to the tire changing process itself. So at that point, I think I'd just get new rims since it's like 100-120 bucks a rim for new vs 80 for a powder coat
My only issue with new rims is none of them have the wide spokes like my stock ones do. I like that look. Plus I like the look of the chrome on black contrast
Nice! Thanks for posting that pic!
I'm painting my rims TONIGHT. I want to use rustoleum black primer and flat black.
Did you use that video? How did you prep exactly?
edit: i was just going to pick up some assorted sandpaper as well
97 Suburban
8 custom PSI Platform 3 18's
Lots of sanding, then a wipedown with alcohol to get rid of any grease or oils
If you are using their flat black enamel: be warned that it takes a LOT of time to cure and harden.
And be gentle with the rims too - it's still just spray paint lol
got it, check
Ok, thanks for the warning, but are you saying longer than overnight?
If you don't mind, what paint did you use?
97 Suburban
I used the rustoleum pro enamel. It takes a few weeks to harden since it's oil based
I was going to use the 'stop rust' type...bad idea!?
97 Suburban
