micker Posted December 5, 2012 Report Share Posted December 5, 2012 When does cone area and power exceed the efficiency of a ported box in spl yes i used search option first, and its not a question that I've seen asked this is all in theory, so all in a perfect world and car so lets say i have 2.5cuft gross to use, and no more for this to be a fair, and an equal playing field, lets say all the speakers suggested will be sundown E series all will be on max recommend power as well, torres was used for the ported boxes @ 14sq" of port to 1cuft net or as close as i could get options would be 1 ported 12 in 1.3net @33hz 17"sq of port (recommend 1.5-2net) 400rms 1 ported 10 in 1.25net @33hz 17"sq of port (recommend 1-1.25net) 400rms 2 ported 8 in 1.2net @33hz 17"sq of port (recommend 1-1.2net/0.5-0.6each) 400rms, 200each 1 sealed 15 in 2.35net (recommend 2.5net) 400rms 2 sealed 12 in 2net (recommend 2net/1net each) 800rms 400each 4 sealed 10 in 2net (recommend 2net/0.5each) 1600rms 400each 8 sealed 8 in 2net (recommend 2net/0.25each) 1600rms 200each cone area and power 97.18"sq on 400rms 12mm xmas (1x 12" ported) just under optimum net 61.85"sq on 400rms 12mm xmas (1x 10" ported) 82.54"sq on 400rms 10.5mm xmas (2x 8" ported) 151.17"sq on 400rms 12mm xmas (1x 15" sealed) just under optimum net 194.37"sq on 800rms 12mm xmas (2x 12" sealed) 247.4"sq on 1600rms 12mm xmas (4x 10" sealed) 330.19"sq on 1600rms 10.5mm xmas (8x 8" sealed) Link to comment Share on other sites More sharing options...
Joe X Posted December 5, 2012 Report Share Posted December 5, 2012 Hi Micker, welcome, port the maximum external dimensions for a box and the vehicle you are placing this in, efficiency can be affected by aiming of the speakers, quality of power and signal..the equipment you are using, the frequency response you want... etc Link to comment Share on other sites More sharing options...
john253a Posted December 5, 2012 Report Share Posted December 5, 2012 Let me try to see what you are asking Will 80-100sq"of cone in a port box on 400rms Be louder then 250-330sq" of cone in al sealed 1600rms Whan you only have a set space to work within Sealed v's port it a hard 1 as every car and setup is different I've never actuly tried this with 2 boxes both have with same gross, And see what I louder Would be intersted to see if anyone has some comparisons where the have tyred Link to comment Share on other sites More sharing options...
micker Posted December 6, 2012 Author Report Share Posted December 6, 2012 yes of couse fitting 8x 8" in 2.5gross is going to be hard but im between 4x sealed 10" v's 1x 10 ported or even 2x 8 ported now i dont want to make it a v's thread i just what to know at what point will power and cone area exceed spl in a ported box Link to comment Share on other sites More sharing options...
EdgarG0721 Posted December 6, 2012 Report Share Posted December 6, 2012 I always wondered this 2 Link to comment Share on other sites More sharing options...
