davinci701 Posted December 6, 2012 Report Posted December 6, 2012 I finally got it hooked up wires are good right fuses and shuts off and on when starting to hit hard wired at 0.5 ohm got a 350amp alt 5 d31s could it be defective or ?
SnowDrifter Posted December 6, 2012 Report Posted December 6, 2012 Protect mode? Or stops playing? Check your voltage at the amp with a DMM at the amp. It should be .5 stable You get the warranty? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
soundstream15 Posted December 6, 2012 Report Posted December 6, 2012 bad ground? does that amp handle 0.5 ohm? you may have a short in a speaker wire..i had some install bay speaker wire before, had it for 2 days, amp would shut off and come back on, go into protect. so switched out the speaker wires and fixed the prob. look into that
aleroking Posted December 6, 2012 Report Posted December 6, 2012 doesnt sound like its protecting since it comes in and out. has to be an rca or wire. 2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
davinci701 Posted December 6, 2012 Author Report Posted December 6, 2012 Gronds are loose will check speaker wires later and didnt get the warranty but .5 stable it says voltage is 13.8
tacomaguy1 Posted December 6, 2012 Report Posted December 6, 2012 Where's it grounded? Before I.fixed my grounds I was dropping to 10v, wired to. 5 they'll handle it Team Flex Issues
aleroking Posted December 6, 2012 Report Posted December 6, 2012 grounds are loose? thats prolly your problem be careful i had a loose ground and smoke started pouring out the trunk i ran up with my fire extinguisher but the wire was already pretty much melted away. 2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
aleroking Posted December 6, 2012 Report Posted December 6, 2012 and voltage is 13.8 with or without the music playing? 2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
soundstream15 Posted December 6, 2012 Report Posted December 6, 2012 you say loose ground? that is your prob right there, where is your amp grounded?
davinci701 Posted December 6, 2012 Author Report Posted December 6, 2012 13.1 with music a few posts were loose bumpin now thanks guys
