IBleedMusick Posted January 2, 2013 Report Posted January 2, 2013 tight box man just curious why you put bracing on that box? arent you vvx12s? Go into the right thread need to talk about his amp rack now lol. This box needed to be braced he's running 1 1700 to each VVX box needs to stay as still as possible. It's built solid and well might I add. To the guy who built it NOICE. 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback
elflako17 Posted January 2, 2013 Author Report Posted January 2, 2013 tight box man just curious why you put bracing on that box? arent you vvx12s? lol you can aski cleansierra whats going on with the box he is the master behind this box hahah 2010 Mazda 3 *Rebuild Time* Subs - (2) AA Mayhems 12's Sub amp - (1) Populus Audio TPA 6500 Headunit - Pioneer App Radio 2 Batteries - XS Power (1) D3100 up front | 6 XP950 rear Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1 Alternator - Singer 260 Externally Regulated Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors) Mids & high Amp : (2) Populus Audio 100.4 Processor: Rockford 3sixty.3 The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
CleanSierra Posted January 2, 2013 Report Posted January 2, 2013 tight box man just curious why you put bracing on that box? arent you vvx12s? It's braced because those 12s are air movers. I would've double baffled the box had I known Skars would be used. The threaded rod will keep the box from destroying itself on the power that he intends to put to those VVXs. The box should be a solid performer and put up some numbers if he can keep his voltage up. Im not the one you want to try to troll. Just a fyi for you.
john253a Posted January 2, 2013 Report Posted January 2, 2013 dont stress about the size to much, its not perfect but will still work, i would have tuned it a bit higher35-37hz as you would have got a bit more net and port area, you just buy some polly mat and line the outside of the box(its not much but will assist) or another little trick i like to do is get some gutter guard the plastic woven mesh, and make a cage accross the back or 1 side of the box and fill that area up with pollyfill, then staple the guard in place, or if you have the depth fill a pillow case up and securer that to back wall
