Help with electrical upgrade. Opinions needed
As of right now I have a 250 amp alternator, supposedly puts out 150 at idle. 2 xs d3100 1 in front and 1 in rear. Big 3 is done. I am running about 2500 watts ( 2 alpine pdx 1.1000 and alpine f4 (4*100)) off of one run of zero gauge wire. What is the max watts I can upgrade to before I start looking into a bigger alternator or a 2nd one. Also when do I start adding more runs of zero gauge.
depends on your usage and how brave you are.. I'd personally get nervous around 3500 with that setup.
as always run a voltage meter and the electrical system itself will tell you when too much is too much.
It depend´s for what you realy want to use your system. Going to comp´s, daily beater. For a dayli setup i would do not more than 5 K on amps
and sometimes the batt´s on the charger.
"in the abundance of water, the fool is thirsty" Bob Marley
Just keep an eye on the voltage and turn it down for a little while when the voltage starts to get low. Time is the major variable that nobody takes into consideration. You can run 10,000 watts on a stock alternator, just not for very long before voltage falls to an un-safe level.
If you want to hammer 5K WRMS all day long without voltage drop, look into a bigger or additional alternator.
  • Who's Online   0 Members, 0 Anonymous, 1511 Guests (See full list)
