What size battery (extra battery)
do the big 3 in 1/0 gauge? alt case grounded to frame, alt power wire to batt, batt grounded to frame? amp grounded to frame? do these first as they will help a lot in maximizing your electrical if you haven't yet. from there a d3100 or d3400 or equivalent should be good and ground it to the frame.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
the d3100 is awesome! you should go with that for sure.
02 impala
VM-1
2 dc 12 xl's
RF t2500bdcp
Second skin damp pro
Kenwood head unit
240 mechman alt
d3400 in the front
d3100 in the rear
50ft Rockford fosgate ofc 1/0
That or if you plan on upgrading in the future to more power, look into the d7500, and you will be set on voltage for a little while.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
are they selling them now? cause i tryed looking for them to buy but couldnt find a website for them i know they made them but cant find them to buy
02 impala
VM-1
2 dc 12 xl's
RF t2500bdcp
Kenwood head unit
240 mechman alt
d3400 in the front
d3100 in the rear
D3100 would be overkill for 2200 rms. But the more electrical, the better. I would think with a big 3 done properly and a yellow top up front, the voltage wouldn't drop that low. XS Power is about the best you can get, if your budget allows it. But a d3400 should be more than enough. Corona_jeff is an authorized dealer here on the forum and he can cut you a deal.
Audio Build
Ride: 2002 Chevy Blazer 4 door
Head Unit: Pioneer deh-80prs
Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith
Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2)
Mids/Highs Amp: Skar 85.4
Mids/Highs: Skar components
Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31
Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/
Perfomance Build
2003 Nissan 350z
Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU
Exedy Racing Clutch, Built Motor by Racing Innovations
Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels
466rwhp
Bike
2008 Midnight Blue Kawasaki ZX-14
Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
Honestly, in your shoes, I would first do away with that Yellowtop and get some XS under the hood. If you need a supplemental battery at that point spring for the largest one you can afford and call it quits.
I'm gonna hate
If it were me, I'd replace the battery up front with an agm one, get a small battery to go in the back clost to the amp, then get the biggest alt your budget allows. IMO having the power on tap would be better than having to keep drawing more than your alt can supply.
  • Who's Online   0 Members, 0 Anonymous, 1722 Guests (See full list)
