K-Swift Posted December 19, 2012 Report Share Posted December 19, 2012 Can someone make me a design for 2 12" Alpine Type R subwoofers. I need it to be 4 cubes, and want to have it tuned to 33hz. My trunk dimensions are 40 W, 21.5 H and 23 D. Any help or suggestions would be appreciated too. The journey is the reward! http://www.stevemeadedesigns.com/board/garage/vehicle/2113-kia-sportage/ Link to comment Share on other sites More sharing options...
WadeTustian Posted December 19, 2012 Report Share Posted December 19, 2012 just plunk those dimensions into torres 2007 Mazda 3 Sedan Pioneer 80-prsB2 Zero.7 2 15s 4inch coil psi recones temp til my subs are reconedFocal P165-v15Audison voce quattro fully activeOnly gonna get louder 146.1 at 38hz 138.x at 24hzBuild log http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/ Link to comment Share on other sites More sharing options...
Joe X Posted December 19, 2012 Report Share Posted December 19, 2012 Here is a suggestion: Enclosure Specifications: Fb = 33 Hz Vb = 4 ft^3 External Height = 16 in External Width = 37 in External Depth = 19.5 in Port Width = 3 3/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2x Front = 16 5/8 x 14 1/2 Back = 37 x 14 1/2 Left & Right Sides: 18 x 14 1/2 Top & Bottom = 37 x 19 1/2 Shared Port Internal Assembly Parts: 2 x Front to Back = 16 1/8 x 14 1/2 2 x Extension = 4 9/16 x 14 1/2 Assembly guide (generic dimensions): - The 45s if you want to do them are 2 1/2" wide except the ones inside the port, if you want to do those let me know. - All trunk boxes built outside the car need to fit in their way in not just have the right dimensions. - The port needs 3 3/4" of free airspace in front of it for proper operation. - Setting your amp's subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
K-Swift Posted December 19, 2012 Author Report Share Posted December 19, 2012 that works, could I do this and have the subs facing up? The journey is the reward! http://www.stevemeadedesigns.com/board/garage/vehicle/2113-kia-sportage/ Link to comment Share on other sites More sharing options...
Raptorman Posted December 19, 2012 Report Share Posted December 19, 2012 Would be louder to have them firing backwards. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies. Link to comment Share on other sites More sharing options...
K-Swift Posted December 19, 2012 Author Report Share Posted December 19, 2012 Would be louder to have them firing backwards. Ok thanks The journey is the reward! http://www.stevemeadedesigns.com/board/garage/vehicle/2113-kia-sportage/ Link to comment Share on other sites More sharing options...
K-Swift Posted December 19, 2012 Author Report Share Posted December 19, 2012 Here is a suggestion: Enclosure Specifications: Fb = 33 Hz Vb = 4 ft^3 External Height = 16 in External Width = 37 in External Depth = 19.5 in Port Width = 3 3/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2x Front = 16 5/8 x 14 1/2 Back = 37 x 14 1/2 Left & Right Sides: 18 x 14 1/2 Top & Bottom = 37 x 19 1/2 Shared Port Internal Assembly Parts: 2 x Front to Back = 16 1/8 x 14 1/2 2 x Extension = 4 9/16 x 14 1/2 Assembly guide (generic dimensions): - The 45s if you want to do them are 2 1/2" wide except the ones inside the port, if you want to do those let me know. - All trunk boxes built outside the car need to fit in their way in not just have the right dimensions. - The port needs 3 3/4" of free airspace in front of it for proper operation. - Setting your amp's subsonic filter to 28Hz is suggested. Would I be able to get this out of one sheet of MDF? The journey is the reward! http://www.stevemeadedesigns.com/board/garage/vehicle/2113-kia-sportage/ Link to comment Share on other sites More sharing options...
teamace24 Posted December 20, 2012 Report Share Posted December 20, 2012 Yeah one sheet would i made a box for two 15 using one. 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31 Link to comment Share on other sites More sharing options...
