SMZ2 Posted December 23, 2012 Report Posted December 23, 2012 I was installing my new tenney alternator and I believe the stock belt it too short. It will fold on to the end of the alt but thats it I can't get it to slide on the pulley. What do I need to do? Also where should I ground on the back of the alt? My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
tacomaguy1 Posted December 23, 2012 Report Posted December 23, 2012 If it wont fit then obvioulsy its too short Team Flex Issues
RobertR Posted December 23, 2012 Report Posted December 23, 2012 Make sure you are getting full travel from your tensioner pully. BMW 325i Kenwood KVT-647DVD re xxx components re 6.5 FR's 2 RE XXX 12's 2 US amps MD3D's 2 batcap 4k's
SMZ2 Posted December 23, 2012 Author Report Posted December 23, 2012 Fixed got a new belt! Now I just have to figure out where to ground or figure out the size of the bolt for the ground. My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
Raptorman Posted December 23, 2012 Report Posted December 23, 2012 That bracket looks sketchy. The ground goes on the back where there isn't paint, where you see the bear metal around the center of the alt. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
SMZ2 Posted December 23, 2012 Author Report Posted December 23, 2012 It works though haha. Yeah I'll have to look for a bolt though there wasn't one attached to the alt when I got it... My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
sprkn_ranger Posted December 23, 2012 Report Posted December 23, 2012 The alternator casing is the ground, which grounds through the bracket and ultimately the engine block. Which if you did you big3 already then you should be fine. You could always run some 1/0 from a bracket mounting bolt to the chassis ground or even the neg terminal on the battery if you really feel the need. Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
SMZ2 Posted December 24, 2012 Author Report Posted December 24, 2012 Yeah I found out the size of the bolt on the ground down part. So I will ground the stock ground and eventually upgrade that to 1/0 also I think that would mean I would have the big 4 then. My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
