Ok guys been having a problem with the amp for a while on the 1 channel only im running a tweeter and it keeps cutting in and out and works only when it wants too. This happened before went away for a while and now came back. It only happening to that one channel only. My questions are how do I fix this? And right now is it ok to be running the 2 tweeter on the second channel at 2 ohms? That how I have it since the first channel is working when it wants too..? A lot of info would help thankyou. Yes it not the wiring cause it works fine on the other channel.
This is how the system is.
Sundown 100.4
channel 1/2 tweeters
channel 3/4 mids
running rainbow germaniums
Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX
And put a sealed enclosure in your trunk cut a hole in your deck and call it ported :lol2:
Check your headunit RCA output voltage. I have a sundown 100.4 as well with the same issue, but I know it's my pos hu causing it
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
Also anyone know how to fix the stripped terminals for the speaker wire. Some of the wire got loose and caused the threading to get screwed up.
How did you fix the problem man?
put a multimeter to the rca output on the h/u
Sounds a lot like what happened to my 200.4, sent it to db-r. They fixed it, few months later, started happening again. And even though it was the exact same issue, Sundown turned their back on me. Sold it as is, taking a big loss.
SMD Super Seller
My Feedback Thread
  • Who's Online   0 Members, 0 Anonymous, 1440 Guests (See full list)
