i only have so much room, pls help pick the right subs
Truconcept
RE xxx 12" T-line
DD9512
funky pup... sealed of course
////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
wow those crossfires are the most expensive 12" ive ever seen lol
i dont want 2 sound cheap but im leaning towards the fi Q
1500rms and 28mm xmax for only $314 ea
kinda like the mayhem only $100 more than the Q
no need 2 vs, but i like ascendant and cry i cant buy new smd woofers
having mayhems would just make it worse
**actin bad like a kid at six flags**
Skar ZVX 12s 1500rms, can take 2500rms, but I wouldn't push it too much further than that. Offered in D1 and D2.. Yeah they're retailing for $5-- but you gotta know peope. Or Bstock em, saw them going for $260 after a fresh recone.
Lol hardly. I got a pair for 700 shipped, only a couple cosmetic flaws with the gasket
alright help me please i dont want 2 make another thread lol
if i get 2 fi Q 12" and plan on wiring (1) dc 1.2k on ea
should i get d2 so i can wire them to 1ohm?
i dont remeber exactly, but i think i do not want the p chamfer, high qts option, or i heat ring
for daily music use?
def get internal leads and spider, cooling?
should i sell my dc amps because they will be underpowering?
thanks for advice
it looks like (2) fi Q 12" is no good 4 me
with my enclosure size limits, the best tune i can get from the port is 47hz
leaning heavy towards dc now
i wish i had more help, joe please sign in!
3 fiq10 fit and work if your happ with a 37hz tune
14h x 35w x 20.75d
double baffle front
2x 5" aero port, 15" long
3.7net@37hz
its a tight fit (very tight) but does work)
and you feed them a good clean 5k
or as close as your elect system will allow
edit:
if your not going to feed it more then 3-3.5k idd stick with the 2x fiq12
and with 2x12" you can get the tune down to 28hz if you want,
daily use.
i considered going with 1 powerful 12"
but id like some more cone area than that
thats why im also considering (3) 10's
looks like its down to 2 choices:
dc level 4
fi Q
no vs, but if dc has quicker build times then i would prob go with them
i think itd be easier 2 get a recone from dc than from fi too
i really like fi Q with 28mm xmax and
after a couple dozen pm's to joex (sorry dude)
ive learned that i can build a box a little small for the Q's
and be ok because im slightly underpowering them with a dc1.2k on each sub
i also have a hifonics collossus but i really want 2 stick with dc amps
i was thinking if i need more power i can sell the dc's or use the collossus til i can afford something else
  • Who's Online   0 Members, 0 Anonymous, 941 Guests (See full list)
