Lock This Please
Just got back from a short drive, and while I was out, the music started cutting out. Like go out for a split-second then be right back to normal. It does it every 1 to 2 minutes. Its a very very quick cut out. Only thing I can think is remote wire which I have run through a relay then to the amp.
So, the question: Can a failing relay go off and on as I described above? I am going to try bypassing the relay tomorrow (too dark now), just want to hear some ideas.
SMD Super Seller
My Feedback Thread
mine was doing that a while back couldnt figure it out sense it would always do it while driving...finally went and sat in a parking lot and played music until it happened found out my voltage was dropping into the nines for a split second because the wire connecting in the fuse holder had oxidized
All new wiring and voltage stays above 14.4 the whole time.
Also, does it whether driving or parked.
SMD Super Seller
My Feedback Thread
I know this great place that fixes amps! hahahahaha JK!
1998 Subaru Forester S
DC 7.5K And DC 175.4
270XP DC Alternator
One XS 5100R
Three XS Power XP3000
All XS Power Wire
Two SMD 18's
I ONLY POUND BLOCKS AND PUSSY
I have had guys come to me with fuel pump issues saying there car starts intermittently. I would change the fuel pump but they had the same issue, so I'd scratch my head. Take a sh*t then get back to it. Just for giggles I switch out the relay. And BAM the issue went away. I could see your issue being a relay issue, at the same time my buddy's cheap ab amp did that and we switched it out and it solved the problem. So good luck.
270XP DC Alternator
One XS 5100R
All XS Power Wire
Two SMD 18's
Could be RCA, sub,relay.. I'd do relay or better yet just jumper constant 12v to remote on amp
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
If the contacts are getting dirty and it is in a position where it is susceptible to a lot of movement and vibration it could be possible...... Hell relays are cheap as shit, hit up a radioshit... er, radioshack, and swap in a new one real quick.
I think it could do that, when a relay is going out some times it will surge like what you are saying, I just had my battery going dead in my truck like a month ago and when I test lighted my battery my window relay was surging making my battery die when the truck was off. Soon after the relay went all the way out.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 1092 Guests (See full list)
