Updated System
Amp-Rockford T-1000.1 BDCP pushing 1568 Watts at 1 or 2 ohms.
Subs- (2) Alpine type R 12's (dual 2)
Radio-Pioneer DEH-3500UI
Door speakers-Rockford Punch series 6.5"(2) and 4X6" (2)
Wires-Tsunami 4AWG( soon to be Cadence 0AWG)
Electrical-150 AMP alternator with upgraded battery
Please comment anything that could be better or any helpful tips. or any pointers. Thanks!(:
Vehicle: 2001 Chevy 1500
Radio: Pioneer
Coaxials: Rockford punch 6.5"s and 4x6's
Subs:Skar VVX 10's (dual 2)
Sub Amp: DD M3A
Wire:Raptor 4 Gauge
Electrical:150 amp alt, big 3, reg. batt.
Will you be running the newest model Type r's that handle 1000rms? I ran two swr1243d in a custom built vented box tuned at 32hz on a T1000-1bdcp awhile back and it was impressive. Looking forward to seeing the build! :) What I will point out is that Rockford T1000 will draw a lot of current, I had a 200A alt and a kinetik 2400 in the back and I would almost drop as low as I do now with an SAZ3500.1 on the same electrical set up. Have you looked into doing the Big 3 (possibly big 4) if you havent already?
1991 Nissan Pathfinder
Mechman 240A alt
All wire 100% OFC 1/0
Kenwood KDC-X497
Pair of Kenwood Tweets/Pair of Rockford P1 5x7s
9ft3 vented box ~32hz
2 AQ HDC3 copper coil 18s
SAZ-3500 @ 1ohm
Powerbass ASA 200.2
39 sq. ft. damp pro.
Kinetik 1200&2400(x2)
Im running the previous model ones that handle 600rms and 1800 peak. Im not dropping a single volt and i havent done the big three yet and all i have is the 150 amp alternator and a new duralast battery. strange. whats the big 4? ive heard of the big 3.
Radio: Pioneer
Sub Amp: DD M3A
Wire:Raptor 4 Gauge
Yea those were the model I was running. And hmm I may have a ground not tightened enough somewhere.
The big 4 is everything a big 3 is except theres an extra ground running from the engine block to the alt (-).
Mechman 240A alt
Kenwood KDC-X497
SAZ-3500 @ 1ohm
Powerbass ASA 200.2
Hmmm, maybe. stay tuned for lots of pics tomorrow!
Radio: Pioneer
Sub Amp: DD M3A
Wire:Raptor 4 Gauge
groung the alt to the frame. if your 1000.1bdcp is doing 1568 at 1 and 2ohm then thats the best one they made.
they're rated to do 1000rms at 1 and 2 ohms but they are under rated and are known to get up to 1500 at 1ohm and about 1400 at 2ohm.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   1 Member, 0 Anonymous, 1484 Guests (See full list)
