Cox Posted January 10, 2013 Author Report Posted January 10, 2013 Just seems like there should a very simple answer to this. You'd think someone else would have this problem and a simple little add on would be made. Oh we'll. Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
8ight Posted January 10, 2013 Report Posted January 10, 2013 Usually when I run into issues such as this one I just fabricate something or think of another solution, there are so many little bumps like this with any install. EDIT: Next time I send someone on a fool's errand instead of requesting a left-handed screwdriver, I'm asking for an alternator bolt extender. I'm gonna hate
P4killer_ Posted January 10, 2013 Report Posted January 10, 2013 The simplest thing i can think of is this: Take the terminal off the factory charging wire, get a larger terminal like 1/0 or even 2/0 soldier both the 1/0 for the big 3 and the stock power wire together in the same lug. should solve the issue. Obviously just make sure you crimp it real good, make it very solid. It might not be ideal but something along those lines would easiest. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
shogen Posted January 10, 2013 Report Posted January 10, 2013 you could screw down an aluminum plate that then has mounting points for more connections... you'd have to get someone to fabricate that though... like toolmaker or something like that Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
Cox Posted January 10, 2013 Author Report Posted January 10, 2013 you could screw down an aluminum plate that then has mounting points for more connections... you'd have to get someone to fabricate that though... like toolmaker or something like that That's what I was trying to describe but failed at it lol. Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
Cox Posted January 10, 2013 Author Report Posted January 10, 2013 Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
Cox Posted January 10, 2013 Author Report Posted January 10, 2013 EDIT: Next time I send someone on a fool's errand instead of requesting a left-handed screwdriver, I'm asking for an alternator bolt extender. Double post Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
Cox Posted January 10, 2013 Author Report Posted January 10, 2013 EDIT: Next time I send someone on a fool's errand instead of requesting a left-handed screwdriver, I'm asking for an alternator bolt extender. Lol. Tell em' to buy a few and send me one when they find it lolol Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
SnowDrifter Posted January 10, 2013 Report Posted January 10, 2013 Does it clamp down on the plastic ring or is there a piece of metal under it? You might be able to grind down the ring a bit to expose more threads ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
SnowDrifter Posted January 10, 2013 Report Posted January 10, 2013 You could also take a chunk of aluminum as thick as you can fit, drill 2 holes in it - one for the stock bolt, then put another bold through the other hole and just attach all your wires to your own bolt ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
