Twostrokeking Posted January 10, 2013 Report Posted January 10, 2013 I have two sa-8 v1.5's under the seat of my truck. They are being powered by a fosgate bd1000.1. Big 3 in 0 gauge and 4 gauge, walmart battery and a stock alternator. I tuned my amp with the dd1 but I can't remember what track. (it wasn't my dd1). I had 4 gauge ran to a block in the back and then 8 gauge ran to each amp.. Completely overlooked that when I put in the 8s and the fosgate because previously I only had one mtx 10. Anyways, I have a run of 4 gauge that will be ran to the back when the re cones come so the fosgate will now have its own 4 gauge wire. I only usually play decaf, nothing boosted by myself. What would cause these subs to clip?! People throw way more power at them then I am. Could it have been the previous shitty box I had them in?? Thanks guys. I just want to make sure I dont make the same mistake again. The spider leads were all burnt and broke when I took the subs out.. My Truck BuildSpending money on things I don't need, to impress others I don't know.At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
soundstream15 Posted January 10, 2013 Report Posted January 10, 2013 Playing well below tuning could do it. Find out what track was used bc if its -15db then that is your prob. Box could do it if its prefab and tuned high. I really wanna say whoever set your gains with the dd-1 messed something up bc your spider leads should be burnt up
mdegen Posted January 10, 2013 Report Posted January 10, 2013 Exactly what the guy on top said. It's probably tuned to be playing much louder music and if you could find out what the box is tuned to it would help figure it out a lot
n8ball2013 Posted January 10, 2013 Report Posted January 10, 2013 i only play decaf. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
bigmescan Posted January 10, 2013 Report Posted January 10, 2013 ive been meaning to take mine out and look at the sa8v.2's because i primarily only play decaf SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
TRTC360 Posted January 10, 2013 Report Posted January 10, 2013 not to be a dick but it sounds to me like you don't know when to turn it down, if you push those subs enough to burn and tear the leads there's no way they were sounding perfectly fine when playing it at the volume to cause that damage, probably also playing too far below tuning. '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360
soundstream15 Posted January 10, 2013 Report Posted January 10, 2013 What rms are those subs? I can't remember but if your over powering then that plays a factor on what track to use with dd-1 I use -10db and have zero issues and play decaf as well. But my box is tuned to 32hz and I'm not over powering them. But it sounds like the person used -10 or -15db bc -5db you would no issues. I would try to contact him. What kind of box where you using and what's it tuned at?
Twostrokeking Posted January 10, 2013 Author Report Posted January 10, 2013 Playing well below tuning could do it. Find out what track was used bc if its -15db then that is your prob. Box could do it if its prefab and tuned high. I really wanna say whoever set your gains with the dd-1 messed something up bc your spider leads should be burnt up not to be a dick but it sounds to me like you don't know when to turn it down, if you push those subs enough to burn and tear the leads there's no way they were sounding perfectly fine when playing it at the volume to cause that damage, probably also playing too far below tuning. What rms are those subs? I can't remember but if your over powering then that plays a factor on what track to use with dd-1 I use -10db and have zero issues and play decaf as well. But my box is tuned to 32hz and I'm not over powering them. But it sounds like the person used -10 or -15db bc -5db you would no issues. I would try to contact him. What kind of box where you using and what's it tuned at? Subs are 400 rms i believe. I tuned the amp and i built the box. The box is tuned at 33 hz. I will just turn the gain down a little because i dont have access to a dd1 anymore. My Truck BuildSpending money on things I don't need, to impress others I don't know.At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
n8ball2013 Posted January 10, 2013 Report Posted January 10, 2013 its an underseat box right/ Is your port about seven miles long. smaller box lower tuning means you need a longer port. you may not be as low tuned as you think. tinsels broke = over driven. I dont think a 1000bd has a subsonic on it. is it the old foreman grill looking ones. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
