ehall8702 Posted January 11, 2013 Report Posted January 11, 2013 my sub amp doent have either a subsonic filter nor a bass boost on it (Mmats Pro Audio D1600.1) but i have an old skool line driver with Both adjustments on it, i also have a single DIN EQ with boost also. I havent had a chance to hear what my subs sound like yet with this new amp but at the moment my Orion XTR Pro 15's are in the smallest box they are deigned for. I do plan on building a speced Poerted enclosure oon though. Will it benbefit me to use either my line driver or eq for bass boost? Will it be ok when i build the ported enclosure? my amp is about 1200 RMS @ 1ohm @ 13.9V and subs are 500 RMS and 1000 Max. I know subsonic will be good in the ported box for sure though but not sure about boost. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
soundstream15 Posted January 11, 2013 Report Posted January 11, 2013 Never use bass boost. Unless you like smoke..
jhmeg2 Posted January 11, 2013 Report Posted January 11, 2013 no bass boost, yes turbo boost, yes line driver voltage boost ( a little ) ////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
ehall8702 Posted January 11, 2013 Author Report Posted January 11, 2013 so subsonic filter and line driver and im all in? So boost is good for what? making cheap crap get a little louder? Low power applications? 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
jhmeg2 Posted January 11, 2013 Report Posted January 11, 2013 my sub amp doent have either a subsonic filter nor a bass boost on it (Mmats Pro Audio D1600.1) but i have an old skool line driver with Both adjustments on it, i also have a single DIN EQ with boost also. I havent had a chance to hear what my subs sound like yet with this new amp but at the moment my Orion XTR Pro 15's are in the smallest box they are deigned for. I do plan on building a speced Poerted enclosure oon though. Will it benbefit me to use either my line driver or eq for bass boost? Will it be ok when i build the ported enclosure? my amp is about 1200 RMS @ 1ohm @ 13.9V and subs are 500 RMS and 1000 Max. I know subsonic will be good in the ported box for sure though but not sure about boost. oh snap I missed that, well, no I didnt, I just forgot about it, yeah um might be something you want ////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
jhmeg2 Posted January 11, 2013 Report Posted January 11, 2013 so subsonic filter and line driver and im all in? So boost is good for what? making cheap crap get a little louder? Low power applications? Is'nt that not the goal? I remember when I was a kid thats all adulsts used to say, "listen to that loud crap" ////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
cloud77 Posted January 22, 2013 Report Posted January 22, 2013 None of their amps have subsonic filter, bass boost exc. just make sure you have the crossover frequency set to your liking. You dont need to increase rca V unless you are running off the stock headunit. See how it sounds without these pieces of equipment before you add them. 2004 Grand Prix GT (2) 12" RE XXXs (04/05 XBL^2) 5 cu. ft tuned @ 35 Hz MMATS HD4000.05 MMATS SQ4100 Infinity Kappa components Juice Box black cherry Duralast platinum group 34 1/0 KNU OFC, 2/0 welding Singer 250A
bighossf150 Posted January 27, 2013 Report Posted January 27, 2013 id say no boost I'd say your post count is about to get reset..... Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
Carbon Posted January 27, 2013 Report Posted January 27, 2013 Damn I was like hell yes! I can convince a fellow car enthusiast to go boosted! Do not use bass boost.
