Sheena Posted January 16, 2013 Report Posted January 16, 2013 if plaster is the case, you might want something that is 5ghz and has external antennas on it. 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
Sheena Posted January 16, 2013 Report Posted January 16, 2013 http://www.newegg.com/Product/Product.aspx?Item=N82E16833181119&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Wireless+AP-_-N82E16833181119&gclid=CObSx9PI7LQCFU6mPAodlzYACw something like that.. i bought one of those for a client and it works wonderful. that is a 2.4GHz solution though. and it is a wireless repeater. the setup is very simple. takes 30 seconds to complete. no cables except the power cord required. you could buy two of those, and buy some external antennas for them that are bitchin. bigger antenna, better signal. plaster or not, it wont matter 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
crispy_chick3n Posted January 16, 2013 Author Report Posted January 16, 2013 it just takes a standard wifi antenna? like the ones you put on wifi cards for desktops? This page is crispy_chick3n approved. © crispy_chick3n inc
Sheena Posted January 16, 2013 Report Posted January 16, 2013 yes sir. 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
beaker Posted January 16, 2013 Report Posted January 16, 2013 Hubs are not like switches, and it sounds like you're getting a shitload of collisions. Back when switches where expensive, general rule was to seperate the hubs as much as possilbe with a switch in between. so like this Router | | Hub ---crossover-- Switch ---crossover-- Hub Keep in mind that all data on a hub is shared (10 port 100BT Hub is actually 100 divided by 10). Setting it up this way reduces collisions to just the hub, and wont spread through and slow down the network. New switches/routers usually will autosense if the port is being used as an uplink and will crossover the connection automaticly to another switch/hub. That is also the case with Wireless access points. I would keep as many as you can to load balance the devices to the router. if you're doing 54g and have 8 devices on it, thats 54/8. http://www.newegg.co...N82E16833118143 I've been using those switches 24/7 in my house for 2 years. They're also 40% off right now. I've never had to reboot one and last I checked they had over 30TB that had run through them. Cant beat 8 port gigabit for 17.99.
Sheena Posted January 16, 2013 Report Posted January 16, 2013 nice find beaks. 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
beaker Posted January 16, 2013 Report Posted January 16, 2013 Also forgot to mention, they also have jumbo frame support. I frequently copy from my file server at a sustained 95 megs a second. I just noticed I linked the wrong one, though they look exactly the same. http://www.newegg.com/Product/Product.aspx?Item=N82E16833118148
Basshead89 Posted January 16, 2013 Report Posted January 16, 2013 If you do have 2 modems (internet connections) coming into the house.... the Main Router will have to support Dual WAN's Here is one http://www.cisco.com...c78-501225.html also this http://www.newegg.co...N82E16833124160 and this one http://www.peplink.com/balance/ Basically use one of three I have linked as your main router. All of the switches will do their job. As far as wireless either use wireless repeaters or wireless access points to get full coverage. These are great and come in a 3 pack and can all be managed from one computer with their software. http://www.ubnt.com/unifi if you don't want to worry about getting power to those, use the pro versions of those access points (pro version are standard POE)
kingsuv Posted January 16, 2013 Report Posted January 16, 2013 Don't know about this crazy computer talk, but a 3-4-5 is to square out a corner of a house when framing Designing, building, and shipping boxes. Yahoo IM - kingsuv00If the listening level is too loud, please inform the driver, so he can promptly pull over, and let you out. not many cars can get me to pluggin my ears but this one.......damn. I mean the first minute is ok but that thing just really starts digging deeper and deeper in your earhole till you cant stand it no more. Seems like it does it with relative ease....16 12's on 8 amps.........gotta love it.
