looking for the best way to seal rear hatch and window 2001 yukon
bdog
any body here have any luck sealing there rear hatch or window . i have had a hell of a time tryng to figure out where my low bass have been going i been through many box designs different amps head units and not all thats left is the rear hatch and window.
REP
In for advice, my trunk lid will shake back and forth violently whenever anything below 29hz plays, and it makes a whooshing sound inside the car. I'm stumped.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
i sealed mine shut with black RTV sealant from Autozone. Works good but don't plan on opening the window ever again LOL
Follow my Tweet (Twitter)
huh i didnt think just putting silicone on the seal would work but ok. have you tried to better the rear door/hatch seal?
REP
the black stuff bonds the hatch glass to the stock black gasket. It is the same shit they use for the windshield.
and no, my rear hatch isn't sealed because i still need to open it from time to time LOL
ya im not gluing my hatch shut either maybe ill just find a way to make the seal tighter. Thank you for your advice
REP
get some weather stripping from home depot or lowes and add a layer or 2 thick of it to the door itself. makes a nice tight fit and reduces the rattle from it.
could fill the door with expandle foam to. reduces rattles and adds weight to the door.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
thats what i was thinking too and the best part s its cheep. the door its self is already foamed and dynomatted
REP
then the weather stripping is the next choice. could losen the boltsfor the latch a little bit and push it or give it a little whack with a hammer then tighten the bolts back down. might have to close the door a little harder to get it to latch but would hold it tighter.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
its worked out pretty good between the window and weather striping the rear door jam it made the bass sound way better
REP
