2 American Bass XD 10's box help
bsneon98
Ok cool. 32hz it is!
Having 3 common port walls means that each sub is basically in its own box correct?
Id like to have as little port restriction as possible
3 common wall results in a port on the side like in post #8, two common wall usually result in boxes like the one I posted, if you are building a port on the side enclosure just make sure to adjust the tuning.
Ok thanks a lot man, you've been a huge help.
Something is wrong, port area per foot is too small. IDK if that calc is the same as the old one but if you plug anything into the round port it cancels out the other one. A single 3" port isn't enough for 2 10's. Here's something I came up with, note I'm not a pro at this just trying to help out.
Thanks man, I see what I did there with the ports... stupid mistake lol.
I don't think that there's any differences but a few questions.
How is the port length 37 when the box is only 20 deep, and how did you calculate the woofer displacement?
You would have to make an L shape port, and you measure down the middle like this. 17.75"+19.25"=37" For woofer displacement I guesstimated, like mentioned earlier is usually around .1-.15 per 10"
How can I find out the length of each piece when doing this using Torres?
so ive been playing around with sketch up and torres a bit and i think i got what i want!
please lmk if you see anything that doesnt look right
bear with me this is the first time ive actually used sketch up
how do i determine the lengths of the port walls?
You measure the length of the port along the center line end to end, someone showed how is done, I can see the figure in post #22.
Regarding your Torres interface, the sketchup has a single baffle but you declared an extra baffle layer, leave that field blank so that it matches the sketchup.
Ok. I'll add the double baffle in sketchup today.
Should I add that in the displacements if I add the wall on the inside?
Torres has added the displacement of the second baffle when you declared it, so no, here is a cutsheet for the Torres above just in case:
External Height = 14 in
External Width = 27 in
External Depth = 20 in
Port Width = 3 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 23 1/4 x 12 1/2
Front Internal = 21 3/4 x 12 1/2
Back = 27 x 12 1/2
Left & Right Sides:
Side 1 = 18 1/2 x 12 1/2
Side 2 = 19 1/4 x 12 1/2
Top & Bottom = 27 x 20
L Port Internal Assembly Parts:
Front to Back = 15 1/2 x 12 1/2
Extension = 14 x 12 1/2
Don't need the braces at all.
  • Who's Online   0 Members, 0 Anonymous, 1593 Guests (See full list)
