2 American Bass XD 10's box help
bsneon98
Last time I had my subs out of my current box, I noticed that each woofer has its own chamber. Any reasons behind that and if so what are the differences?
There are a few reasons to use this design: a) it is self bracing b ) since is symmetrical both subs loading is the same c) in the case an L port is obstructed by lateral car bracing the port in the middle can help. Just another option for you to keep in mind.
What do you suggest I do?
You have more experience than I do with enclosures.
Here is another suggestion:
Enclosure Specifications:
Fb = 32 Hz
Vb = 2.4 ft^3
External Height = 14 in
External Width = 28.5 in
External Depth = 18 in
Port Width = 2 3/8 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2x Front = 13 1/16 x 12 1/2
Back = 28 1/2 x 12 1/2
Left & Right Sides: 16 1/2 x 12 1/2
Top & Bottom = 28 1/2 x 18
Shared Port Internal Assembly Parts:
2 x Front to Back = 15 5/16 x 12 1/2
2 x Extension = 8 3/16 x 12 1/2
Assembly guide (generic dimensions):
Sorry for getting into this thread and getting it off topic for the thread starter. But i was wondering if i could use this same enclosure for my 2 10" ssa dcons i have this is somewhat what im looking for the only thing with me is i would like to have subs up port back.
If would a similar box, but different port area, subs up not recommended in trunk cars, not sure what vehicle you have, probably best if you started a thread.
I will start a thread. I have a hatchback integra
Can't say the L ported is just not going to work, anyhow I wouldn't tune that low if I expected to perform any loud.
I always thought that 32 hz was a good happy medium, how is it too low to be loud?
Well I was mainly talking about the 24-29.9Hz ideas in the first post.
Ok cool. 32hz it is!
Having 3 common port walls means that each sub is basically in its own box correct?
Id like to have as little port restriction as possible
3 common wall results in a port on the side like in post #8, two common wall usually result in boxes like the one I posted, if you are building a port on the side enclosure just make sure to adjust the tuning.
  • Who's Online   0 Members, 0 Anonymous, 941 Guests (See full list)
