What are you running on stock alternator?
1995 Mercedes C220
stock 90A alt
DD M2b @.5 omh
jl xd400/4 and DD SS4a both 4 channels wired at 2 ohms.
stock battery and xs D5100 in trunk
Big 5. alt to bat line 4 gauge though all else 0 gauge OFC
drop to 12.1 at idle 12.4 at 2k rpm
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
saz 3500d wired @ .35 ohm (havent clamped to see what reactive is but i assume over 1 ohm lol)
soundstream tx 4.560
stock 130a alt (rebuilt denso) ( no big 3 just lead alt wire in 1/0)
5 group 34 copper top dekas (90 dollar ones)
2 runs of shca 1/0 positive
2 runs of shca 1//0 negative
cold idle voltage: 14.3-4
warm idle voltage 14.2
idle drop (fully charged batteries and 1 song full tilt) low 13s (checked at AMP with dmm)
rev drop 13.6+
idle drop (low batteries or after a song or two) low 12s
rev drop: high 12s
excessive amperage 280a alt is on its way :D (benched at 190 @ idle full output at 1700rpms slightly smaller pulley)
update...
EA alt is (amp tuned with the DD1 and 0db 40hz track slight distortion shown)
full tilt drop @ idle is 13.4
revving i seen 13.7 before i stopped the 5 second burp (40hz 0db track)
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
Stock alt 60 to 80 amps iirc 1990 honda civic
System 1
SD 12k
Batts
Kintic 2400
2 2000's
Stock batt up front
Subs
2 DC XL's
Voltage drop high 11's
System 2
2 stetsom 7ks
Alpine 2 channel 150 watts
earthquake 4 channel 400 watts
Mtx 2 channel 150 watts
Mtx 4 channel 400 watts
Batts
6 kintic 16v's only using 12 volt side so like 6 kinitc 1400's
Stock batt up front
Voltage drop to 12.5 for a couple of hours hard play will drop to 9s after a few hours hard play then need to recharge or daily allways in the 12s
make: 2005 Jeep Grand Cherokee
alt: stock 160amp
battery: stock under hood
big3: no
amps: DC1.2k @2ohm and Kicker KX350.4
aux: overhead DVD
voltage: drops to high 13s
http://www.stevemead...cherokee-build/
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
System 1
SD 12k
Batts
Kintic 2400
2 2000's
Stock batt up front
Subs
2 DC XL's
System 2
2 stetsom 7ks
Batts
Stock batt up front
HOLY SHIT!....all that on a stock 60amp alt?...that year Civic does run a 60amp stock alt
Alpine CDE-hd148bt
Alpine PKG-RSE2
Kicker KX350.4
DC Audio 1.2k
System 1
SD 12k
Batts
Kintic 2400
2 2000's
Stock batt up front
Subs
2 DC XL's
System 2
2 stetsom 7ks
Batts
Stock batt up front
Jebus. Seriously? o.O
Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893
real men dont use fuses :D
Neither do morons
Says the guy with lambo doors on his Ford Taurus.
'03 Trailblazer, stock alt,Big 3 done, Stinger SP1000 up front, MTX 91002, 3404
////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
Yes all that with a stock alt and batt upfront
I havve 7 batts total so I do have a good reserve of power a few hours of hard play after that reserve is gone tho I have to take it easy but with 12 10,s I've only taken it to that point 2 times when doing demos all day other than that its to fucking loud for me to play full tilt ALL the time
  • Who's Online   0 Members, 0 Anonymous, 741 Guests (See full list)
