russtezecustoms Posted April 11, 2013 Report Posted April 11, 2013 Im running a stock 120 amp alt stock batt up front 1 lanzar opti 2000d at .5 1 dual 800x4 at 2 ( i know it dosent do rated but it works.) 2 re audio sxx 15 4 pyle 6.5 2 lanzar opti super tweets Max drop at idle 11.9 Max drop at 1800 rpm 12.4 Im gunna add a marine batt with 160 ah this afternoon. Ill post back up probably tomorrow. I just wish i had a funny sig.
darkjds Posted April 11, 2013 Report Posted April 11, 2013 stock 110 alt kinetik 1400 up front, 800 trunkAlpine mrp-m1000, Kicker zr1000 on mids ands highs (underatedasfuck) Big 3 1/0 Tsunami OFCFull tilt while driving 13.8-13.6Full tilt idle 12.8 Current Setup: , 2 Fi sp4 18s in a big ass flat wall tuned to 23hz, Pioneer 80prs, 2 Digital Designs m3bs strapped @ 2 ohms, Banda ICE2000, Crescendo 800.4, 4 PRV 10MR1000s,4 Mclaren MLT300 Super Tweeters Kinetik 2000 XS Power 2700 & XS Power 3100s.
Mobileaudio25 Posted April 11, 2013 Report Posted April 11, 2013 Alt: 78 amps Sundown 3500W amp and some 600w amp for mids/ highs 2 optima blue tops and 1 xs d3100 all under the hood:) 2/0 welding cable throughout Big 3 Voltage drops to around 10.8-11v that voltage drop scares me
Vito Basser Posted April 11, 2013 Report Posted April 11, 2013 92 jeep cherokee 90 amp alt 2 apsms 1500 strapped at 1.8 1 polk audio 660 starter batteries- redtop, kentic hc800 rear batteries- 2 60 ah agm batteries, 1 stinger 2150 drop to 11.5 if batteries arent charged, 12.5 if they are fully charged What wiring do you have? A neg run from the alt case to rear batteries helped my friend ALOT I'd put the 2150 up front and the 2x 60Ah AGM's in the back near the amps. By ditching the 2 you have up front, the more efficient your charging system will be. Not to mention less weight = more gas miles Let us know if you do
Nate Futuristic Posted April 11, 2013 Report Posted April 11, 2013 Alt: 78 amps Sundown 3500W amp and some 600w amp for mids/ highs 2 optima blue tops and 1 xs d3100 all under the hood:) 2/0 welding cable throughout Big 3 Voltage drops to around 10.8-11v that voltage drop scares me some amps can go all the way down to 8v before protecting lol not saying its good to run that low but yea that is scary down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
slowfkncar Posted April 11, 2013 Report Posted April 11, 2013 Everything copper 0 guage 2 runs of 0 guage pos to rear 0 guage grounds all over my damn car 14+ wires 2 Everstart marine maxx 124ah for a total of 228ah Stock 115? Amp acura tl alternator. Voltage drop 14.2 to 13.4-2 for about 1-2 mins then 11.9-8. Really bad. Its basically the same as playing your sounds with the car not running and having the alternator "charge" the quicky drained batteries. After I have switched to Powermax usa 220amp alt,I never drop below 13.4 full tilt. That's with a saz 2500@1 ohm,and 2 four channels runnign in active with 160amp fuse
russtezecustoms Posted April 12, 2013 Report Posted April 12, 2013 Im running a stock 120 amp alt stock batt up front 1 lanzar opti 2000d at .5 1 dual 800x4 at 2 ( i know it dosent do rated but it works.) 2 re audio sxx 15 4 pyle 6.5 2 lanzar opti super tweets Max drop at idle 11.9 Max drop at 1800 rpm 12.4 Im gunna add a marine batt with 160 ah this afternoon. Ill post back up probably tomorrow. I just got everything hooked up and went and pounded on it for about 20 minutes checked voltage at amp, it was charging at 14.4 at idle worst drop i could get was 12.9 durring hard long hits, immediatly back to 14.4 after end of note. digging it!! I just wish i had a funny sig.
1two3 Posted April 12, 2013 Report Posted April 12, 2013 stock 90-110 alt 1 xs 51r up front big 3 in knu 0 gage t1000 in the process of adding a t400-2 votage drop into the 11s.....too scared to go more Car: 2000 Honda CRV Battery: XS Power D5100R Alternator: Stock 90A Head Unit: Pioneer DEH-X9500BHS Front Speakers: Alpine Type S Rear Speakers: JBL GTO 628's Wires: All Knu 4g. Soon to be 0g. Big 3 in 0g Volt Meter: SMD VM-1 Amps: Rockford Fosgate T400-2, T1000-1bdCP Subs: 2 SSA XCON 15's Sealed Tint: Privacy glass + 5% in the back and 25% in fronts
miniSPLlancer Posted April 16, 2013 Report Posted April 16, 2013 2011 outlander Stock 120 amp alt (smart charge system) 2-AQ 2200 strapped for burps, drop to 11.9 1-AQ2200 for daily Big 3 of course 1/0 pos & neg front to back 2 kinetik 1800's plus stock While driving 12.6 (even with stereo off) Stock idle when started 14.1 (smart charge) when playing system full tilt, 13.3-13.7. 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
Johnp71 Posted April 17, 2013 Report Posted April 17, 2013 P71, Stock Alt. : 200 amp ... (can u believe that !!!) I have a mechman alt., 250 amp, that was never installed. . . Big 3, all Stinger 0 gauge, a single XS Power D3100 battery under the hood. A single Sundown saz 3500d powering TWO FI SP4's 15'' @ 1 OHM. . . ( B2 Audio M1s MKII on the way) 600W RF powering 4 Jbl speakers for mids and highs 14.4V - 13.9V on highway, and i saw it drop down to 12.8 volts couple of times on idle. What you think 2006 P71 270A Mechman alt. 2 XS power D3100's, 1 under the hood, one in the trunk. More to come. 2 Stinger 0 gauge, 4 gauge runs front to back Sony DSX-S300BTX AM/FM Digital Media Car Stereo with Bluetooth Pair of Fi SP4 15''s B2 Audio M1s MKII amp @ 1 Ohm Front doors JBL P660C 6.5'' 2-way component system. Rear doors JBL GT0938 6x9'' 3-way Rockford Fosgate t600 @ 2 Ohm Ram Designs box with 5'' port, ~ 3.6 cubic inches each facing back. 5704P Python 2-Way Responder Remote Start / Security Alarm.
