What alternator should i add to my install???
for one you dont seem to have the knowledge of how it all goes together. if you dont know the difference between a stepdown and an isolator this is not an option for you. stick to 12volt batts.
Another reason is because you do need to top off your batts every so often. Most say once a week. Well you get that 14 volt battery and you now need a 14 volt charger.
you need 1/0 grounds to complete your big three. read the whole big three thread you'll see its talked about in length.
your draw is not that big. regardless of how power hungry that 1000 is it cant be that bad. youve got 1400 watts. figure 200 amps current draw. Thats really nothign. finish your big three add a second battery and a new alt and youre set. dont over complicate it by adding batteries of differint resting voltages.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
2006 Silverado Crew-Cab
Kenwood DNX-8120 - Head unit
4 x JL Audio 8w3's - Subs
Focal K2 Power - 165 v2 - Front - mids/highs
Focal Polyglass - 165 V2 - Rear - mids/highs
JL Audio Slash 1000 v2 - Subs
Alpine 400x4 - mids/highs
BIG 3, Dynomat throughout
X2^^^
Not recharging it will crush it quick.....
Not cool for a very high dollar battery.....
EDIT- if i was you, with the gear you have, id big 3 it, add another battery and call it done.
Your really not pulling a lot.
Sorry took a min to respond. I was watching the vid post. and i have all of this completed on my truck. thats why i was going to add another batt. and either add a 2 or a diff alternator. b/c im still getting a large voltage drop. the big 3 wasnt enough.
Add another battery first, you may not need a h/o alternator
Ill def give the 2nd batt. a go, it couldnt hurt to try, right (lol). Might even save me 3-400buxs (on alternator) if 2nd 12v batt. is enough power. Thank you'll for your paitence and help, it is greatly appricate it, and never overlooked!
I will give the 2nd 12v batt. install a go tom. and report back and let youll know how it goes.
Once Again, Thanks a millinon!!
